Ground Wire |
Ground Wire |
bobforman |
Mar 20 2023, 04:38 PM
Newbie Group: Members Posts: 31 Joined: 7-April 09 From: Seattle Member No.: 10,242 Region Association: Pacific Northwest |
Thinking I had drawn a diagram of all the wires before pulling the transmission, I seem to have neglected the large black ground wire which is now resting on top of the trans. Where does this one attach?
GregAmy |
Mar 20 2023, 06:02 PM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
There should be a 6mm (or is it 8mm?) stud extending from the bottom side of the trunk floor, toward the mid/aft end of the transaxle.
If not, anywhere on the chassis will do. EDIT: BTW, while any good wire will do, the stock one was a braided steel strap. |
bobforman |
Mar 20 2023, 06:58 PM
Thanks, Greg. I've got the braided ground wire hooked up. This one is a round, battery-like cable coming from above the passenger side. I'll have to trace it to its origin and figure out more from that.
technicalninja |
Mar 20 2023, 07:11 PM
Senior Member Group: Members Posts: 1,356 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
The only large cable on my 75 coming from the passenger side is the power supply lead for the starter.
It is black... But it is not a ground. What do you have hooked to the large terminal on your starter? |
bobforman |
Mar 21 2023, 12:23 AM
Thanks, tech. That's got to be the answer.
Lo-Fi Version | Time is now: 12th June 2024 - 12:15 AM |
