Dimensions for front triangle, Forward triangle |
Flyinlow |
Mar 20 2023, 06:48 PM
Flyinlow Group: Members Posts: 36 Joined: 17-October 20 From: British Columbia, Canada Member No.: 24,774 Region Association: Canada |
Hi , was hoping someone could give me a picture and possibly dimensions for the front triangles inside front fenders at front of rockers, mine super bastardized by P.O. Thanks Dennis
Ishley |
Mar 20 2023, 07:33 PM
Member Group: Members Posts: 102 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest |
You can order a new one from Restoration Design near Toronto.
914werke |
Mar 20 2023, 09:13 PM
"I got blisters on me fingers" Group: Members Posts: 10,124 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Nope. At least if I understand what you are describing.
The R&L triangle sections in the frunk attached to the front cross wall on the 73-74 cars ... are not currently being reproduced. I wish they were. (IMG:style_emoticons/default/smile.gif) |
Ishley |
Mar 21 2023, 10:24 AM
Perhaps I didn’t understand what you are looking for. I thought you were looking for the ones in the front trunk area.
What year is the car? |
914werke |
Mar 21 2023, 10:52 AM
These are re-manufactured & exist on all cars
What I was referring to are the "bows" that are still triangle shaped & help to reinforce the front crosswall. @peteyd |
Flyinlow |
Mar 22 2023, 07:11 AM
I was referring to the ones at the front of rockers inside wheel well that I believe are larger than the ones on threshold…. Will fabricate what I need with pic or dimensions
peteyd |
Mar 28 2023, 08:57 AM
Senior Member Group: Members Posts: 707 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
Sounds like he needs the front sill triangle. No one reproduces that piece yet.
Pete |
friethmiller |
Mar 28 2023, 10:11 AM
Member Group: Members Posts: 498 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
I just went out to my car and grabbed the part for you. Here's a pic of what I have left of it (IMG:style_emoticons/default/sad.gif) . Yes, this car has A/C, so ignore the hole(s). The second pic is my "back of the napkin" sketch with some rough'd in dimensions I took directly from the part. I'm not much of a draftsman! The third shows the inside bend and how the outer edge width increases as it moves up the part. I've fabricated these in the past without too much difficulty. I mainly used a vise, if I remember correctly. Your mileage may vary but this should get you close. Good luck!
Flyinlow |
Mar 29 2023, 07:48 AM
I just went out to my car and grabbed the part for you. Here's a pic of what I have left of it (IMG:style_emoticons/default/sad.gif) . Yes, this car has A/C, so ignore the hole(s). The second pic is my "back of the napkin" sketch with some rough'd in dimensions I took directly from the part. I'm not much of a draftsman! The third shows the inside bend and how the outer edge width increases as it moves up the part. I've fabricated these in the past without too much difficulty. I mainly used a vise, if I remember correctly. Your mileage may vary but this should get you close. Good luck! This will help… thanks so much |
914werke |
Mar 29 2023, 08:37 AM
How many do you need?
SirAndy |
Mar 29 2023, 09:53 AM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
friethmiller |
Mar 29 2023, 10:06 AM
Funny! You can see why I have to go all the way to bare metal with this BB LE car. Just look at this part! Most of the car is like this. Rust is like a web under all of the original black paint. It typically comes right off with Ospho (or the like). Places where it's bad, you almost can get the paint out of the rust without sandblasting or direct metal replacement. No worries. This will be the one I drive when I hit retirement in a few years. (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 6th June 2024 - 05:09 AM |
