| mate914 |
Apr 10 2023, 07:04 PM
Matt ![]() ![]() ![]() Group: Members Posts: 936 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States
What is done with bearing cover? Does 911 backing plate replace bearing cover or do we modify bearing backing plate and use both together?
thanks Matt |
| mepstein |
Apr 10 2023, 07:18 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,632 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
One or the other. Not both.
| mate914 |
Apr 10 2023, 07:33 PM
| Retroracer |
Apr 11 2023, 08:50 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 655 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest
What is done with bearing cover? Does 911 backing plate replace bearing cover or do we modify bearing backing plate and use both together? thanks Matt I made up spacer plates that both cover the bearing and set the 911 backing plate to the correct depth for the brake shoes to sit centered in the drum (for the handbrake function). I believe the required spacing is something like 5mm from memory? Chris Foley or Eric S would probably know the correct offset, - Tony |
| Luke M |
Apr 11 2023, 02:27 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,500 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
What is done with bearing cover? Does 911 backing plate replace bearing cover or do we modify bearing backing plate and use both together? thanks Matt There's two parts to the 911 e-brake setup. The backing plate itself and a bearing cap. You'll need both items from an early 911. Plus you know you need to weld on a backing bracket for the e-brake shoes correct. Get Chris Foleys e-brake cable parts and good to go. |
| mepstein |
Apr 11 2023, 04:13 PM
Sorry. I meant you use the 911 parts. Not the 911 and 914 together. My mistake for not being clear.
| mate914 |
Apr 11 2023, 07:00 PM
Can you show me the parts diagram of the outer bearing cap and or parts number.. Auto Atlanta shows none.... looking at pelican now.
Matt What is done with bearing cover? Does 911 backing plate replace bearing cover or do we modify bearing backing plate and use both together? thanks Matt There's two parts to the 911 e-brake setup. The backing plate itself and a bearing cap. You'll need both items from an early 911. Plus you know you need to weld on a backing bracket for the e-brake shoes correct. Get Chris Foleys e-brake cable parts and good to go. |
| mate914 |
Apr 11 2023, 07:02 PM
| mate914 |
Apr 11 2023, 07:03 PM
also have the tangerine kit....
| mate914 |
Apr 11 2023, 07:33 PM
90133156100 is not available. alternatives?
Matt |
| mepstein |
Apr 11 2023, 10:00 PM
90133156100 is not available. alternatives? Matt Amazon, ebay, ect Attached thumbnail(s) |
| mate914 |
Apr 12 2023, 04:50 AM
Got some coming.
Thanks, Matt |
Lo-Fi Version | Time is now: 16th April 2026 - 09:29 AM |
