Full Version: 911 emergency brake conversion question
mate914
What is done with bearing cover? Does 911 backing plate replace bearing cover or do we modify bearing backing plate and use both together?
thanks
Matt
One or the other. Not both.
mate914
Thanks Mark
Matt
QUOTE(mepstein @ Apr 10 2023, 09:18 PM) *
Retroracer
QUOTE(mate914 @ Apr 10 2023, 05:04 PM) *
thanks
Matt
I made up spacer plates that both cover the bearing and set the 911 backing plate to the correct depth for the brake shoes to sit centered in the drum (for the handbrake function). I believe the required spacing is something like 5mm from memory? Chris Foley or Eric S would probably know the correct offset,
- Tony
Luke M
QUOTE(mate914 @ Apr 10 2023, 06:04 PM) *
thanks
Matt
There's two parts to the 911 e-brake setup. The backing plate itself and a bearing cap.
You'll need both items from an early 911. Plus you know you need to weld on a backing bracket for the e-brake shoes correct. Get Chris Foleys e-brake cable parts and good to go.
Sorry. I meant you use the 911 parts. Not the 911 and 914 together. My mistake for not being clear.
mate914
Can you show me the parts diagram of the outer bearing cap and or parts number.. Auto Atlanta shows none.... looking at pelican now.
Matt
QUOTE(Luke M @ Apr 11 2023, 04:27 PM) *
thanks
Matt
mate914
I understood what you were saying.... I guessed the same thing.
Matt
QUOTE(mepstein @ Apr 11 2023, 06:13 PM) *
mate914
also have the tangerine kit....
mate914
90133156100 is not available. alternatives?
Matt
QUOTE(mate914 @ Apr 11 2023, 09:33 PM) *
Matt
Amazon, ebay, ect
mate914
Got some coming.
Thanks, Matt
