More 6 conversion questions, ??? |
Markeydoo |
Aug 13 2005, 01:04 PM
??? Group: Members Posts: 246 Joined: 10-April 03 From: Socal Ventura Member No.: 557 Region Association: None |
OK I am confused (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)
What are people doing to the stock relay board to make it work with the 6 conversions. I have a 914-6 engine wire harness and a 75 relay board. Is ther any modifications that I need to do? if so what?? I have goten some feed back but I am still confused to what I need to do. Thanks Mark |
Root_Werks |
Aug 13 2005, 05:24 PM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Mark, do a title only search for "Root" or even "Root Werks", look for a 6 conversion thread with a flared orange car. I remove the relay boards now a days, but kept the relay board on that car. I noted some terminal swaping for the charging ect. that need to be done.
You should keep and use your 914-4 engine harnes. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Porsche Rescue |
Aug 13 2005, 06:36 PM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
Mark, I think Dan is referrring to his conversion thread which is now in the "classic " threads section. Page 4 of the thread talks about wiring the regulator.
It is confusing to me Dan. I am finishing a conversion now and plan to use the board (unless you talk me out of it). Can you explain the "terminal reversal" on the regulator one more time please. |
Al Meredith |
Aug 13 2005, 07:03 PM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
Automobile Atlanta has a booklet that covers 4 to 6 conversion. Very inexpensive . I sure this issue is covered
goose2 |
Aug 13 2005, 09:55 PM
Senior Member Group: Members Posts: 976 Joined: 30-March 05 From: Eugene, Oregon Member No.: 3,847 Region Association: Pacific Northwest |
Dan's the Man on six wiring as far as I'm concerned. My engine room is SOOO tidy. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Sparky |
Aug 14 2005, 09:40 AM
Mahna Mahna! Group: Members Posts: 1,134 Joined: 21-June 03 From: Spencer, MA Member No.: 847 |
I, like so many other lemmings, bought the book. Though there are some helpful sections this is not covered well at all. Your best bet is to review the posts here and then ask lots and lots of questions. Mike D. |
Marv's3.6six |
Aug 14 2005, 10:19 AM
Actual member 7" Group: Members Posts: 695 Joined: 22-November 04 From: Huntington Beach, Ca. Member No.: 3,165 Region Association: Southern California |
Mark, you can HAVE my relay board from my orig six if you want.
I will not be using it on my 3.2 to 3.6 upgrade. |
JFJ914 |
Aug 14 2005, 10:32 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
I am not a "lemming" but bought the booklet well before this forum exsisted. IIRC it had the pinout conversion neatly detailed in two CLEAR diagrams. Does everything mentioned about AA have to start a flame war? Grow up! |
IronHillRestorations |
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Alot of the decision making has to do with the engine you are going to install. A carb'd engine is much easier, especially if you've got a internally regulated alternator, although you can delete the relay board if you have a externally regulated alternator and mount the regulator elsewhere.
Another issue to consider is the fuel pump relay. If you've moved the fuel pump and aren't using the original fuel pump circuit, then you don't have to deal with this. There is a factory connector that will plug right into the existing harness, but the connector and pins alone costs $45! I do custom harnesses for six conversions, and sell DIY kits. I use wiring with color coding the same or as close as possible to factory. I also use black PVC jacketing and heat shrink for a real OEM appearance (I HATE black electrical tape wiring harnesses (IMG:http://www.914world.com/bbs2/html/emoticons/icon8.gif) ). PM me if you want more info on what I have to offer. |
J P Stein |
Aug 14 2005, 02:10 PM
This is about as close as you can get to someone drawing out a custom wiring diagram for you.....jump on it. I went thru the conversion in my pre-internet days. The electrical part was my biggest challenge....I still have the AA booklet somewhere (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Markeydoo |
Aug 14 2005, 06:20 PM
Thanks All
The engine, alt, and enging wire harness are all out of a 914-6. The body wire harness are original 914-4 75' This should be fun!!! Marv I'll take you up on your offer Thanks |
Lo-Fi Version | Time is now: 9th June 2024 - 02:21 PM |
