100 mm/6 bolt Axle Set Up, 911SC Componets/ 944 CV's |
914Sixer |
May 1 2023, 02:27 PM
914 Guru Group: Members Posts: 8,902 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Just got these pieces finished up. Did gun barrel finish on these parts. Ready to assemble full floating axles with 944 CV's. Rear hubs are plug and play with 914-6 rotors.
Attached image(s) |
r_towle |
May 1 2023, 04:06 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
when all is done, what are you using for rear brakes?
E-brake? rich |
914Sixer |
May 1 2023, 04:12 PM
Stock 914-6 rear calipers. You can use stock -4 if you turn rotor down.
r_towle |
May 1 2023, 04:27 PM
is there an integrated e-brake on the 911 caliper?
or is it a drum? rich |
914Sixer |
May 1 2023, 06:10 PM
No ebrake is a plate mounted on the trailing arm.
r_towle |
May 1 2023, 07:25 PM
Now I need to go look at my 911 to see what is up.
Ebrake still works great, but I never looked at it. Aside from 5 lug, what is the benefit of doing it the way you are doing it? I have the complete front sitting in a box….mainly because the rears are hard todo. Right now, adapters. |
bahnzai |
May 1 2023, 07:30 PM
Member Group: Members Posts: 307 Joined: 26-July 06 From: Columbia, SC Member No.: 6,509 Region Association: South East States |
Looks fantastic. It is a shame to cover them up!
mepstein |
May 1 2023, 07:44 PM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Now I need to go look at my 911 to see what is up. Ebrake still works great, but I never looked at it. Aside from 5 lug, what is the benefit of doing it the way you are doing it? I have the complete front sitting in a box….mainly because the rears are hard todo. Right now, adapters. Bigger CV's hold up better with a bigger engine. 911 hubs accept 911 rotors. |
Steve |
May 1 2023, 10:43 PM
914 Guru Group: Members Posts: 5,611 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
914Sixer |
May 2 2023, 05:48 AM
Yes, the need external spacers from Patrick Motorsports.
Attached image(s) |
Lo-Fi Version | Time is now: 7th June 2024 - 12:12 AM |
