Screw Without A Home M8x15, Help with an oil cooler install. ‘73 2.0 |
trick-e |
May 1 2023, 06:09 PM
Still Learning Group: Members Posts: 115 Joined: 7-July 12 From: Traverse City, MI USA Member No.: 14,644 Region Association: Upper MidWest |
So, I’ve replaced the oil cooler, having dropped the engine and removed the fan shroud, alternator, etc., and in spite of my best efforts, have a screw left over.
Can anyone help me identify where this M8X15 belongs? Attached thumbnail(s) |
Dave_Darling |
May 1 2023, 06:58 PM
There is one hole for the engine tin that is oversize. It's for the right-side tin piece that goes over the cylinders and head, but it's on the edge of the tin nearest the centerline of the engine. I am not certain that it's an M8 hole, but it's larger than M6.
--DD |
r_towle |
May 1 2023, 07:23 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I have so many of those screws (IMG:style_emoticons/default/smile.gif)
trick-e |
May 1 2023, 08:27 PM
There is one hole for the engine tin that is oversize. It's for the right-side tin piece that goes over the cylinders and head, but it's on the edge of the tin nearest the centerline of the engine. I am not certain that it's an M8 hole, but it's larger than M6. --DD Hmmm. Thanks Dave. I’ll take another look. |
Mikey914 |
May 2 2023, 08:14 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Cheese head engine tin screw Probably missing one in your tin easy to do.
brant |
May 2 2023, 08:41 AM
914 Wizard Group: Members Posts: 11,639 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Isn’t there an m8 like that on the 2 piece square bracket that holds the cooler?
It’s been a while since I’ve done that job So could be wrong Maybe check the PET? |
Lo-Fi Version | Time is now: 8th June 2024 - 02:35 AM |
