Oil Temp Sensor Connection, 914 6 Conversion |
mmascari |
May 7 2023, 07:31 PM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
Does anyone know where I might be able to get the electrical connector to connect my oil temp sensor? It has not been connected since I installed the 3.0l engine. I am not familiar with electrical connector like this. See pic below, the terminal on the sensor is round.
Attached image(s) |
nditiz1 |
May 7 2023, 07:49 PM
Senior Member Group: Members Posts: 1,190 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Should be able to use a regular female spade connector. I think that's how my temp sensor is rigged up.
Dave_Darling |
May 7 2023, 07:53 PM
I believe a standard ring terminal will work; IIRC that part on the end is threaded so you can unscrew it and put a ring terminal over the stud.
--DD |
mmascari |
May 7 2023, 08:49 PM
davep |
May 8 2023, 07:00 AM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Should be able to use a regular female spade connector. I think that's how my temp sensor is rigged up. Thanks, I think I was overthinking this. The standard flag style terminal slides right over it. Yes, a regular quarter inch flag connector |
davep |
May 8 2023, 07:01 AM
The only trick will be the boot over the terminal.
Lo-Fi Version | Time is now: 2nd June 2024 - 03:46 AM |
