Axles first or engine?, Axles first or engine? |
Boothy |
May 8 2023, 12:17 PM
Member Group: Members Posts: 88 Joined: 17-January 19 From: Abington, MA Member No.: 22,805 Region Association: North East States |
Cheers all!
Getting ready to put the engine back in. FINALLY! Should the axles go in first or does it matter? |
friethmiller |
May 8 2023, 01:58 PM
Senior Member Group: Members Posts: 500 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
Highland |
May 8 2023, 07:30 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
Are you installing the engine/transmission as a unit with the exhaust? If the exhaust is on, I think axles first and tie them up to the springs so they stay up and out of the way.
If you're installing the exhaust later, I think it matters not; but still probably easier first. |
r_towle |
May 8 2023, 07:41 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I seem to recall that the easiest way is to install axles first.
If my memory is correct, you cannot install the axle with the male stub end all assembled because you won’t have room once the engine and transmission are installed. Secondarily, if you choose to install the cv to cv axle assembly with the engine in the car, you have little if barely any clearance to get a tool in to tighten up the axle at the wheel end. |
Boothy |
May 9 2023, 09:40 AM
The exhaust will go in after. I'll get the axles squared away and installed first -then hung up.
Thanks for the advice. I appreciate the help!!! One step closer. (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 11:06 AM |
