1975 Ljet dual relay ground wire |
Geezer914 |
May 15 2023, 08:04 AM
Geezer914 Group: Members Posts: 1,438 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Does the ground wire in the 12 pin connector wire harness going to the dual relay, plug 2, connect to the engine grounds under the plenum?
dr914@autoatlanta.com |
May 15 2023, 08:32 AM
914 Guru Group: Members Posts: 7,893 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
should be a male spade at the connection point for the tension clip for the bellows rod to the right front of the distributor
Lo-Fi Version | Time is now: 5th June 2024 - 02:08 PM |
