ID Turn Signal |
ID Turn Signal |
morehills |
May 23 2023, 05:21 AM
Newbie Group: Members Posts: 29 Joined: 2-March 23 From: Great Barrington, MA Member No.: 27,202 Region Association: North East States |
Can anyone help me with this turn signal. The car is a '71 but I don't know if the column or mechanism has been changed. Is this a proper '71 column?
The signal works and pops up this the but does not return. What is the proper part to replace it? Thank you for any help, John Attached image(s) |
Front yard mechanic |
May 23 2023, 06:29 AM
Senior Member Group: Members Posts: 1,169 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Maybe it’s on upside down
914Sixer |
May 23 2023, 02:48 PM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Plastic ears are broken off and spring is missing. This is a late switch but it will give you an idea. I may have some ears and a spring from broken ones that you might be able to fix yours with. Have to check warehouse.
Attached thumbnail(s) |
Type 47 |
May 23 2023, 02:51 PM
Senior Member Group: Members Posts: 783 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
I replaced mine, on my 75', with one from Auto Atlanta.
some plastic piece most likely broken, or it could be because your tach is upside down. |
dr914@autoatlanta.com |
May 23 2023, 03:23 PM
914 Guru Group: Members Posts: 7,885 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
70 71 column with a 911 end tab put on to it. You need the 70 71 turn signal switch. we have many R91461392712
morehills |
May 23 2023, 03:51 PM
Lo-Fi Version | Time is now: 31st May 2024 - 11:28 PM |
