WTB : Headlight switch repair, WTB: Head light switch repair |
porscheteck914 |
Jun 6 2023, 10:06 AM
Newbie Group: Members Posts: 30 Joined: 23-March 23 From: n.c. Member No.: 27,247 Region Association: North East States |
WTB : Do we have any Brain surgeons in the club that can repair the rheostat part of the 914 Head light switch ? Last couple of switches I have bought do not have good adjustment. TOO dim then, off , then TOO bright. (IMG:style_emoticons/default/wacko.gif) thanks and best regards
bdstone914 |
Jun 6 2023, 02:05 PM
bdstone914 Group: Members Posts: 4,536 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
WTB : Do we have any Brain surgeons in the club that can repair the rheostat part of the 914 Head light switch ? Last couple of switches I have bought do not have good adjustment. TOO dim then, off , then TOO bright. (IMG:style_emoticons/default/wacko.gif) thanks and best regards You can jumper the two wires to keep them full bright. I think it is 56a and 56b. |
porschetub |
Jun 6 2023, 04:56 PM
Advanced Member Group: Members Posts: 4,704 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
WTB : Do we have any Brain surgeons in the club that can repair the rheostat part of the 914 Head light switch ? Last couple of switches I have bought do not have good adjustment. TOO dim then, off , then TOO bright. (IMG:style_emoticons/default/wacko.gif) thanks and best regards You can jumper the two wires to keep them full bright. I think it is 56a and 56b. (IMG:style_emoticons/default/agree.gif) waste of time this function as the lamps are so weak anyway ,best solution is to add led's then the dimmer can be bypassed as above cause it won't work anyway. Don't think the switches can be repaired if they have that issue and who is brave enough to open one up....not me so I did when Bruce mentioned a while back. Cheers. |
porscheteck914 |
Jun 6 2023, 07:26 PM
JeffBowlsby |
Jun 7 2023, 09:06 AM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I have wondered if one of the VW beetle/ghia/bus/thing headlight switches could be made to work as a substitute. Have not looked into it but we know the circuitry of the 914 switch as a place to start.
These are new switches that are not expensive and readily available. Attached image(s) |
Lo-Fi Version | Time is now: 7th June 2024 - 11:57 AM |
