FOUND: Two Hole Rubber Grommet, ...for fuel lines |
Bullethead |
Jun 16 2023, 04:47 PM
Oil Cooled heart Group: Members Posts: 897 Joined: 24-June 10 From: South Florida Member No.: 11,875 Region Association: South East States |
In need of the grommet used at the front bulkhead for the hard fuel lines. Or an alternative if anyone has suggestions.
Odd size that I haven't found using the interwebs, like 15 x 42mm. Thanks! |
914werke |
Jun 16 2023, 05:08 PM
"I got blisters on me fingers" Group: Members Posts: 10,142 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
1TRICK6 |
Jun 16 2023, 06:13 PM
Newbie Group: Members Posts: 45 Joined: 13-July 11 From: Southern California Member No.: 13,313 Region Association: Southern California |
In need of the grommet used at the front bulkhead for the hard fuel lines. Or an alternative if anyone has suggestions. Odd size that I haven't found using the interwebs, like 15 x 42mm. Thanks! Try this 914 world vendor http://www.914world.com/bbs2/index.php?showtopic=110158 |
Bullethead |
Jun 17 2023, 06:45 AM
914werke |
Jun 17 2023, 10:29 AM
So IIRC the earliest cars used plastic fuel tunnel lines from front to back, but were replaced at some point with lines that the forward-most ends had a formed steel barbed section that poked through the grommet.
Those lines were asymmetrical sized. The pressure side smaller than the return so on the early version of the grommet the hole sizes matched the lines. It had only 2 holes for the lines since the charcoal evap system & cannister was in the cowl with 2 large vinyl lines running along the drvrs side long & into the the eng bay. That was changed on the later cars where the charcoal can was moved to the Eng. bay & the 2 vinyl lines were replaced with a single small (4mm) line that also poked through that grommet & now ran down the tunnel into the eng bay. That change coincided with moving the pump to the front so the lines changed material & became symmetrically sized as did the holes in the grommet. |
Bullethead |
Jun 20 2023, 08:03 PM
Success... thanks Rich, got an offering from Garold, problem solved. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 10th June 2024 - 05:38 PM |
