Replacement grommet for speedo cable ? |
Literati914 |
Jul 9 2023, 08:37 PM
Senior Member Group: Members Posts: 1,473 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I have a very usable speedo cable except the bulbous rubber grommet that fits to the fat tube at the firewall in the engine compartment.. it’s a bit tattered. I’m not seeing replacements for just this detail, checked 914rubber and a general search. Anyone have a solution, whether it’s a replacement or… ?
914Sixer |
Jul 10 2023, 05:51 AM
914 Guru Group: Members Posts: 8,900 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
No replacements that I know of, only comes on new cable.
Mikey914 |
Jul 10 2023, 09:33 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Comes with a new cable. One of the reasons we didn’t make them.
Literati914 |
Jul 10 2023, 01:16 PM
Well I’m gonna have to come up with a (cheap) solution for the time being since my cable is just fine otherwise. The small end of this particular grommet is in tact, the large end is split in a few places, so it sits loose… I may wrap it with a strip of sheet rubber and a hose clamp.
This has to be a bit common, I’d think a more professional solution would be popular. Like the same piece produced with a linear split down the side that would slip over the tube/cable and get contact glued into place (made slightly over sized and glued over itself). Though I realize it’s probably cost prohibitive to produce. Oh well, I’ll get a new cable eventually. BTW, I can’t quite understand why the tube is so big to begin with? Doesn’t seem necessary to me. . |
DennisV |
Sep 19 2023, 01:34 PM
Member Group: Members Posts: 482 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
I have a very usable speedo cable except the bulbous rubber grommet that fits to the fat tube at the firewall in the engine compartment.. it’s a bit tattered. I’m not seeing replacements for just this detail, checked 914rubber and a general search. Anyone have a solution, whether it’s a replacement or… ? I think I am in the same boat. Is this the speedometer one you were looking for? What did you end up doing? Are the brake grommets meant to be accordion (914-424-592-00) I assume that clutch and accelerator cables don't have boots / grommets at the firewall? |
Lo-Fi Version | Time is now: 3rd June 2024 - 09:46 AM |
