rfinegan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,083 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region ![]() ![]() |
I am thinking about painting the case, valve covers and heads with a thermal dispersion coating to get rid of some heat more efficiently . Has anyone tried this before?
https://www.cerakote.com/shop/cerakote-coat...7/transfer-grey. Grey is ok, but would like black or silver 35 bucks for a sampler.... |
Van B |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,621 Joined: 20-October 21 From: WR, GA Member No.: 26,011 Region Association: None ![]() ![]() |
I'm going to do a lot of cerakote air cure on my car too. Transfer grey is their color of choice for high emissivity (absorbs radiant energy) and piston coat is the low emissivity reflects coating of choice.
That said, if you search by high emissivity, you'll see that they rate the blacks as a good heat transfer coating. |
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,863 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
rfinegan |
Charcoal thermal transfer paint from Cerakote is one the way (air cure) this is going on the OUTSIDE of the case heads and cylinders. Other accents will be Black VHT paint. A little effort to make this one look Pretty(ier) and hopefully a little cooler running
MORE to Come.... Here is a pic of the color f rom the CeraKote Gallery (not mine) ![]() |
Shivers |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,082 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California ![]() |
QUOTE “35 bucks for a sampler....” Please let us know how much product It actually takes to coat those parts. A few degrees is a few degrees, especially where I live. (IMG:style_emoticons/default/blowup.gif) |
rfinegan |
Paint arrived today(fast shipping)
Now I need more Acetone (cleaner) and about 6 cans of brake clean and a roll of painters tape.... |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,169 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
I recall researching this many years ago, and if memory serves (it often doesn't) black anodize was the best for thermal transfer.
(IMG:style_emoticons/default/idea.gif) |
rfinegan |
Van B |
So that’s transfer grey? It does look nice!
worn |
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,492 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
I am thinking about painting the case, valve covers and heads with a thermal dispersion coating to get rid of some heat more efficiently . Has anyone tried this before? https://www.cerakote.com/shop/cerakote-coat...7/transfer-grey. Grey is ok, but would like black or silver 35 bucks for a sampler.... They told me in more than one physics class that black radiates best. That may be a generalization though that doesn't always apply. I like the matte look. |
rfinegan |
WOOHOO...I got the case Cerakoted today. The 4 oz was just enough to get the job done (less the trans side of the case) Had I not been so generous on the heads and cylinders , there is more that enough in the sample 4oz size. I did use an old set of jugs to keep the paint of the register so I did not have to mask...This works out well..pics to follow in 25 hours cure time or sooo....
-Cheers |
rfinegan |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,970 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Looks good but I’m not sold on the value. I’m guessing it’s incremental compared to a properly placed oil cooler with a fan pack.
rfinegan |
Value= 40.00 bucks for a cool paint job that look good and will last better than engine paint at about the same cost...
Bonus= possible reduction of 10 to 50 degrees (so I read on web articles ) So I am in for either.... I think Ham Heads have a thermal coating on the outside of the heads too as well as ceramic coatings in the chambers...so there must be benefits other then looks Thanks for the support and feedback...external cooler is next if temps creep..but for now...cheep and EZ and I think looks pretty good too -Cheers Looks good but I’m not sold on the value. I’m guessing it’s incremental compared to a properly placed oil cooler with a fan pack. |
cassmcentee |
Member ![]() ![]() Group: Members Posts: 228 Joined: 12-July 18 From: Squaw Valley, CA Member No.: 22,304 Region Association: Central California ![]() ![]() |
Woke up this morning with a thought regarding heat retention...
Been cleaning my split case halves for over a week now. Every time I think that they are clean (exterior) I am able to draw more grease/grime out and have to go at it again. Sort of like cleaning a dirty sponge, I honestly can't believe how porous these cases are. Doing the coating as you are makes so much sense! By sealing the case with the coating, you are effectively sealing the pores in the "Sponge" Now all of the areas where oil/grease would collect within the case faces are greatly reduced. Over time, build up will be greatly reduced and thus heat retention will be reduced as well. Thank you for this post as I am going to do the coating now as well! |
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,609 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
Woke up this morning with a thought regarding heat retention... Been cleaning my split case halves for over a week now. Every time I think that they are clean (exterior) I am able to draw more grease/grime out and have to go at it again. Sort of like cleaning a dirty sponge, I honestly can't believe how porous these cases are. Doing the coating as you are makes so much sense! By sealing the case with the coating, you are effectively sealing the pores in the "Sponge" Now all of the areas where oil/grease would collect within the case faces are greatly reduced. Over time, build up will be greatly reduced and thus heat retention will be reduced as well. Thank you for this post as I am going to do the coating now as well! Why not just they’re clear? I have a bunch of air cure on my -6. Works well and super tough. |
cassmcentee |
QUOTE Why not just they’re clear? I have a bunch of air cure on my -6. Works well and super tough. You make a good point! The clear would achieve the grime/grit barrier but not the faster heat dissipation. Back in the 90's I had Jet Hot Coatings in AZ, ceramic coat in mat black, the exhaust for my 1946 Indian Chief (1200cc with a 40mm Mikuni) Made an amazing difference in kicking the heat away. |
mb911 |
QUOTE Why not just they’re clear? I have a bunch of air cure on my -6. Works well and super tough. You make a good point! The clear would achieve the grime/grit barrier but not the faster heat dissipation. Back in the 90's I had Jet Hot Coatings in AZ, ceramic coat in mat black, the exhaust for my 1946 Indian Chief (1200cc with a 40mm Mikuni) Made an amazing difference in kicking the heat away. No they have a clear that is designed for what your doing |
cassmcentee |
No they have a clear that is designed for what your doing Ohhh! Good call Only it won't hide all of my grinding scars from cleaning up the casting (IMG:style_emoticons/default/rolleyes.gif) |
worn |
Value= 40.00 bucks for a cool paint job that look good and will last better than engine paint at about the same cost... Bonus= possible reduction of 10 to 50 degrees (so I read on web articles ) So Cool looking paint is just as important as cool running paint. If you get both, bonusaroo. |
Lo-Fi Version | Time is now: 14th July 2025 - 07:26 AM |
