painting the trim black on the engine lid Need some photos |
rick 918-S |
Jul 13 2023, 08:45 PM
Hey nice rack! -Celette Group: Members Posts: 20,494 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Need some photos of the engine lid paint under the grille and the area under the side grilles.
Literati914 |
Jul 14 2023, 09:07 AM
Senior Member Group: Members Posts: 1,479 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Need some photos of the engine lid paint under the grille and the area under the side grilles. When you say trim, I suppose you’re referring to the actual grill material, and/or the letters? I’d just use SEM trim black or even Rustoleum satin black. Don’t have any pics yet but I’ll be painting the frame under the grill material black, as the small side areas were done from the factory. I’m pretty sure this area was body color on all 914s, though I’ve always considered it ..wrong. I’d only do it that way for a concours car but it’s Jmho. I do like the understated nature of letters painted black too, and have considered it for one of my builds. . |
dr914@autoatlanta.com |
Jul 14 2023, 09:46 AM
914 Guru Group: Members Posts: 7,898 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
brant |
Jul 14 2023, 12:26 PM
914 Wizard Group: Members Posts: 11,641 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I sprayed flat black also
Masked around the top face. Did not go but hardly over the top face 1/16 or so But used a gloss on the mesh |
bob164 |
Jul 14 2023, 12:35 PM
Member Group: Members Posts: 96 Joined: 10-February 18 From: SoCal Member No.: 21,877 Region Association: Southern California |
Root_Werks |
Jul 14 2023, 01:00 PM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Rick,
Just went through this a bit ago: http://www.914world.com/bbs2/index.php?sho...;hl=grill+paint I opted for a Satin black for the grill and under the grill. -Dan |
jonferns |
Jul 14 2023, 02:45 PM
Advanced Member Group: Members Posts: 2,081 Joined: 29-March 07 From: New Jersey Member No.: 7,631 Region Association: North East States |
rick 918-S |
Jul 14 2023, 03:48 PM
Thanks! Question: did you paint the engine side of the grille area black also? Jon is the engine side of grille area on yours Black? This is for Juergen's factory 6.
jonferns |
Jul 14 2023, 05:55 PM
Thanks! Question: did you paint the engine side of the grille area black also? Jon is the engine side of grille area on yours Black? This is for Juergen's factory 6. Rick - Grilles are black on both sides. Engine lid structure is painted black on the topside only. The underside (side facing engine) is body color; see below. This is on my '74; lid is original paint. |
rick 918-S |
Jul 14 2023, 07:42 PM
Thanks! Question: did you paint the engine side of the grille area black also? Jon is the engine side of grille area on yours Black? This is for Juergen's factory 6. Rick - Grilles are black on both sides. Engine lid structure is painted black on the topside only. The underside (side facing engine) is body color; see below. This is on my '74; lid is original paint. Thanks! that is exactly what I needed. |
Literati914 |
Jul 14 2023, 10:11 PM
[.. I’m pretty sure this area was body color on all 914s, though I’ve always considered it ..wrong. Not sure where I got that but from all the comments, I’m off on that statement, sorry. I do have these lids with body colored frame tops, as well as a third for the car I’m working on now - it was the same way (I’ve got it in primer atm). . Attached image(s) |
wonkipop |
Jul 15 2023, 01:44 AM
Advanced Member Group: Members Posts: 4,403 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
we just did one, lid and sides are flat black, grilles themselves semi gloss, we paint with Wurth trim paint Need some photos of the engine lid paint under the grille and the area under the side grilles. the dr. is dead right if its an accurate original paint job you are after. flat black on the upper surfaces of the frame. the grille itself is different. semi gloss for sure. and don't forget the little bit with the rubber buffer on it. i'm looking at my original from factory and i swear they hand painted those areas after applying main body paint. with a brush. the dr, can comment on my opinion re brush. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beer.gif) |
mlindner |
Jul 15 2023, 07:37 AM
Senior Member Group: Members Posts: 1,531 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Shivers |
Jul 15 2023, 09:01 AM
Senior Member Group: Members Posts: 2,436 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
TheCabinetmaker |
Jul 15 2023, 11:04 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Thanks! Question: did you paint the engine side of the grille area black also? Jon is the engine side of grille area on yours Black? This is for Juergen's factory 6. Rick - Grilles are black on both sides. Engine lid structure is painted black on the topside only. The underside (side facing engine) is body color; see below. This is on my '74; lid is original paint. Thanks! that is exactly what I needed. Rick, I've only seen a couple of cars with the lid structure painted black, and they all had overspray on the bottom. Both my personal cars have been body color on top. |
rudedude |
Jul 16 2023, 08:57 AM
Senior Member Group: Members Posts: 511 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest |
Rick,
Did you get enough info to paint the lid? I could take pics of mine pretty sure it hasn't ever been touched Jule |
rick 918-S |
Jul 16 2023, 10:41 AM
Thanks Jule. I think I did. The grille is going to have to come back off when the car gets to Spain to have a rubber seal added between the lid and the grille. I couldn't reuse the one on the grille. It was brittle. And I do not have the side grilles here. So if the finish on the grille turns out different when Juergen starts to paint the side grilles they can be matched all at the same time.
Lo-Fi Version | Time is now: 11th June 2024 - 05:04 PM |
