Spot Welder |
Spot Welder |
Montreal914 |
Jul 15 2023, 01:44 PM
Senior Member Group: Members Posts: 1,591 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
I am considering getting a used 120V spot welder. My thinking is the older rugged style the better vs. new cheapy stuff?
Anyone successfully using 120V system on their restoration work? This type (not necessarily this one) of system? Any model/brand I should look for on offerup/craigslist? Thank you for sharing experience/comment! (IMG:style_emoticons/default/smile.gif) |
rick 918-S |
Jul 15 2023, 05:39 PM
Hey nice rack! -Celette Group: Members Posts: 20,494 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I have fried 2 of those like the one pictured only 240V. Would not buy a 120 version. The 240V one works. I have an old Lenco I use. I use it to install body panels instead of plug welding.
tomeric914 |
Jul 15 2023, 05:44 PM
One Lap of America in a 914! Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
If you're spot welding two pieces of 30 gauge tin, the 120 volt unit might work.
I have the 240 volt Horrible Freight spot welder which has worked fairly well up to two pieces of 20 gauge. |
Montreal914 |
Jul 15 2023, 06:31 PM
Perfect, exactly the type of answer I was looking for.
I have a drier outlet not too far from the garage, maybe I can plug into it. (IMG:style_emoticons/default/idea.gif) I will focus on 240V units Lenco. I did see a couple of them on CL. Thank you for the input. (IMG:style_emoticons/default/smile.gif) |
76-914 |
Jul 15 2023, 11:12 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,510 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Another option; build one. You'll need to harvest the transformer from an old microwave. Other than that you'll need to construct the loop. there are several "How to" videos on YouTube and they all use the same construction method. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif)
tygaboy |
Jul 16 2023, 07:57 AM
914 Guru Group: Members Posts: 5,319 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
Don't go "cheap". I tried the Harbor Frieght model and it was... disappointing. I ended up with a Quick Spot II from HTP Weld. This was a few years a go so the price was a bit lower. You can also get different length/shape arms to get to those hard-to-reach places. It works a charm! https://usaweld.com/products/quick_spot_ii Attached thumbnail(s) |
Lo-Fi Version | Time is now: 11th June 2024 - 06:09 PM |
