3.2 Engine fire! How to clean. |
Mate914@gmail.com |
Jul 15 2023, 05:13 PM
Matt Group: Members Posts: 10 Joined: 9-July 17 From: 17758 Member No.: 21,237 Region Association: North East States |
I just had an engine fire. Car was warm pulled out and saw flames out the rear view mirror. My Element did not work. Next one did but did not stop fire. 40 year old fire extinguisher did the job!
What is the best solution for removing the extinguisher residue from the PMO carburetors and the engine? Could have been much worst! Saved the car! Matt (IMG:style_emoticons/default/flag.gif) |
Mate914@gmail.com |
Jul 15 2023, 05:17 PM
Mate914@gmail.com |
Jul 15 2023, 05:19 PM
mb911 |
Jul 15 2023, 05:22 PM
914 Guru Group: Members Posts: 6,871 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Wash right away. Make sure nothing goes down the carb throat and if by mistake it does vacuum that out right away. I would be using dish soap myself
BeatNavy |
Jul 15 2023, 05:24 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
That sucks, Matt. No help here other than I hope you get it sorted out without major problems.
JeffBowlsby |
Jul 15 2023, 05:28 PM
914 Wiring Harnesses Group: Members Posts: 8,526 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
What’s the chemistry of the fire extinguisher used? I thought a standard FE left an acidic residue? Find out and use the correct cleaner and fast!
Mate914@gmail.com |
Jul 15 2023, 05:30 PM
What’s the chemistry of the fire extinguisher used? I thought a standard FE left an acidic residue? Find out and use the correct cleaner and fast! I have very limited service here and cannot research it. I have to use multiple hotspots to get these messages out. I used an element extinguisher and I also use a standard camper extinguisher about 40 years old, not sure it’s composition. Matt (IMG:style_emoticons/default/flag.gif) |
Mate914@gmail.com |
Jul 15 2023, 05:31 PM
Going for dishwasher, soap and water rinse now. Wish me luck.
nditiz1 |
Jul 15 2023, 05:38 PM
Senior Member Group: Members Posts: 1,190 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Don't know the best method, glad it was saved, unhappy to hear 1 element didn't do the job. I am running them in my cars.
mepstein |
Jul 15 2023, 05:56 PM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Drop the engine and trans and start cleaning. Without knowing the right thing to do, I would probably use dawn dish soap and water with baking soda mixed in. I would probably take the engine down to a long block and clean each piece individually and get under the fiberglass shroud. Then wipe everything down with wd40 to give all the exposed aluminum and steel some protection.
Mate914@gmail.com |
Jul 15 2023, 06:20 PM
Drop the engine and trans and start cleaning. Without knowing the right thing to do, I would probably use dawn dish soap and water with baking soda mixed in. I would probably take the engine down to a long block and clean each piece individually and get under the fiberglass shroud. Then wipe everything down with wd40 to give all the exposed aluminum and steel some protection. Thank you. Matt |
bkrantz |
Jul 15 2023, 08:11 PM
914 Guru Group: Members Posts: 7,792 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
From the Guardian Fire service web site:
Dry chemical fire extinguishers use firefighting agents such as monoammonium phosphate, sodium bicarbonate, and potassium bicarbonate. These leave behind a corrosive powder, so it’s important to clean up dry chemical fire extinguisher residue quickly, especially if it has come in contact with metal surfaces. Vacuum or sweep up loose debris. Spray stuck-on residue with isopropyl alcohol diluted 50 percent with warm water. Let the solution sit for several minutes, and then wipe with a damp rag. To neutralize sodium bicarbonate and potassium bicarbonate residue, apply a solution of 98 percent hot water and 2 percent vinegar. After several minutes, wipe the area with a damp rag. To neutralize monoammonium phosphate residue, apply a baking soda and hot water paste. After several minutes, wipe the area with a damp rag. Give the affected area a final wash with soap and water, and then rinse clean. Use fans to help the spot dry quickly. That matches my memory that dry chem stuff is chemically basic, and corrosive--and needs to be neutralized with a mild acid. |
Mate914@gmail.com |
Jul 15 2023, 08:33 PM
I rinsed good today..
Tow home then strip down. Thanks for you help guys. Matt (IMG:style_emoticons/default/flag.gif) |
Ottomotion |
Jul 15 2023, 10:35 PM
Newbie Group: Members Posts: 45 Joined: 12-January 23 From: Central California Member No.: 27,090 Region Association: None |
What was the root cause? Line, fitting...?
r_towle |
Jul 15 2023, 10:39 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
That sucks!
I would follow the sage advice here based upon experience. |
Shivers |
Jul 16 2023, 08:21 AM
Senior Member Group: Members Posts: 2,411 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
So sorry.
ConeDodger |
Jul 16 2023, 08:41 AM
Apex killer! Group: Members Posts: 23,606 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
mate914 |
Jul 16 2023, 02:05 PM
Matt Group: Members Posts: 753 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
I got the car cleaned off as best as I could at the location I was in. I just got back with the car on the trailer and took a few photos. I am now going to do the baking soda and vinegar wash downs. I will be dropping the engine tomorrow morning. I think the fire started inside the air cleaner assembly.
mate914 |
Jul 16 2023, 02:06 PM
mate914 |
Jul 16 2023, 02:09 PM
Lo-Fi Version | Time is now: 2nd June 2024 - 04:39 PM |
