914 Rubber round relays vs. old oem round relays..., Looking for some reviews on the new ones....comments? |
second wind |
Jul 20 2023, 02:50 PM
Senior Member Group: Members Posts: 857 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Hello family....I bought some of the 914 Rubber round relays when they came out but also have about 20 of the original round relays. For some reason I am having intermittent relay failure in my engine compartment relay board. When I realize that my fuel pump is not going on I swap a few relays and then the pump will run again. The primary theory is that the pins are not making good contact in the board sockets. I have cleaned everything and tried spreading the pins open a bit but still having an occasional failure. I am thinking that using brand new relays should be a better idea than trusting 50 year old relays....what say you?
Thank you very much, gg |
Krieger |
Jul 20 2023, 03:21 PM
Advanced Member Group: Members Posts: 4,729 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Try the 914 Rubber ones. I had a prolem with the ones I bought until I spread the pins on them. Carry spare relays. Don't keep playing musical chairs with your relays you will never be able to narrow down what the problem is.
porschetub |
Jul 20 2023, 03:48 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Hello family....I bought some of the 914 Rubber round relays when they came out but also have about 20 of the original round relays. For some reason I am having intermittent relay failure in my engine compartment relay board. When I realize that my fuel pump is not going on I swap a few relays and then the pump will run again. The primary theory is that the pins are not making good contact in the board sockets. I have cleaned everything and tried spreading the pins open a bit but still having an occasional failure. I am thinking that using brand new relays should be a better idea than trusting 50 year old relays....what say you? Thank you very much, gg Good move I had a bag of relays I purchased from a member on here and they all tested fine ,also recieved spare ones when I bought the car ,slowly but surely the number of good ones is reducing. Pulled a few apart and most had burnt/worn out contacts,took one and removed the guts and bridged the pins as a test relay which turned out to be handy. |
Lo-Fi Version | Time is now: 11th June 2024 - 11:21 PM |
