Problem with emergency flasher indicator lights staying on |
JMTaxter |
Aug 12 2023, 08:57 AM
Newbie Group: Members Posts: 14 Joined: 28-July 11 From: Thousand Oaks, California Member No.: 13,371 Region Association: Southern California |
Hi, guys.
Having a problem with my emergency flashers. When I start the engine, both flashing green light emergency indicators at the top of the tach/speedo stay on constantly. Won't shut off. None of the exterior emergency lights are malfunctioning/staying on, in other words, they function as they should. The emergency brake has been released. The relay is new. Of course, the emergency switch is off. All turn signals and lights operate properly. I did notice with the emergency switch on, the speed of the flashing decreases; turn the switch off, and the speed increases again. If you have any insight, I'd really appreciate it. Thanks in advance for your advice. John |
Rob-O |
Aug 13 2023, 09:37 AM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
I’ve found that what happens is that even though the emergency/parking brake handle has been released, the arm isn’t making contact with the switch that is on the floorboard just under the handle. Get a long screwdriver and push the parking brake switch and see if the light goes out. The switch looks identical the the ones found in the front door jambs.
Spoke |
Aug 13 2023, 11:28 AM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Is the new flasher an OEM replacement? What p/n is it? It sounds like you have an incorrect flasher installed. I agree with Rob-O that either the e-brake switch is not closed, or the master cylinder warning switch is tripped, or you have some leakage in those wires.
Does the brake light flash as well? However the e-brake or MC warning switch should not trigger the turnsignal indicators in the tach. |
Lo-Fi Version | Time is now: 7th June 2024 - 06:34 PM |
