nivekdodge |
Member ![]() ![]() Group: Members Posts: 309 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region ![]() ![]() |
Wondering what doesn’t belong here. Fiberglass rear pan hits resonator on muffler and muffler isn’t covered by the pan. Ideas?
Kevin |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,379 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
Hi- Pictures would help in identifying the issue.
(IMG:style_emoticons/default/beerchug.gif) |
nivekdodge |
nivekdodge |
![]() ![]() ![]() Attached image(s) ![]() |
BillJ |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,307 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None ![]() ![]() |
You mean valance
When you lay it flat on a flat surface is it bent at all? They have some flex so have tried to just push it up and secure? Otherwise your car may be a little tweaked... |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,958 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Fiberglass means it’s aftermarket so that’s one reason it might not fit. Usually you have to fit fiberglass to the car. Cut, clamp, glass. Rinse and repeat. Or the car got hot and it’s out of whack.
nivekdodge |
It’s a fiberglass valance which sloppy is expected but it doesn’t hide the muffler nor fit there
Shivers |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,075 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California ![]() |
A stock valance will not cover the whole stock muffler. It didn’t on mine.
nivekdodge |
This is how close it is to the rear body panel
kevin Attached image(s) ![]() |
scallyk9 |
Member ![]() ![]() Group: Members Posts: 355 Joined: 16-October 16 From: Port Orchard, WA, USA Member No.: 20,499 Region Association: Pacific Northwest ![]() ![]() |
It’s a fiberglass valance which sloppy is expected but it doesn’t hide the muffler nor fit there Your FG replica does look a bit shallow in height but not far from a later model original steel one which does not cover the muffler and only has a half-circle cutout for the tailpipe. The early year rear valances with the hole for the tailpipe did cover the muffler but did a great job of scooping snow and dirt; probably the reason for the later design. |
nivekdodge |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,031 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
This is how close it is to the rear body panel kevin It looks like you have an early 1.7 muffler that had a different exhause pipe location. It used the deeper porthole valance. They stopped making the deep valanceas it made the engine run hotter. You may be able to make that one work. I have seen several valances that were so farr of that they could never fit. |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,338 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
What Bruce said!
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,856 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
Your car is a 74 1.8?
Have you looked into getting the stock muffler for your car? Then try to get a steel valance? That may correct all of the issues at once. I doubt you will regret getting the original stuff. Obviously, the valence can be a little difficult to find in pristine shape, but “aged” ones can be found. |
nivekdodge |
I looked up the muffler on Auto Atlanta's sit and it appears to be correct and the same one I have unless there are small differences
Kevin |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,736 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
That muffler doesn't look like it is in the right place which goes along with what Bruce said. It should be centered up with that heat shield. From what I can see it looks quiet a bit to the rear of center. (IMG:style_emoticons/default/confused24.gif)
Shivers |
nivekdodge |
Im looking for a measurement from the back of the tranny to bottom of the rear body panel?
Lo-Fi Version | Time is now: 8th July 2025 - 04:22 PM |
