wires on the coil, haynes sucks |
tat2dphreak |
Aug 17 2005, 09:51 AM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
ok, I replaced my coil before putting the engine back in... last night I was wiring up everything...
my old coil was clearly marked "+" and "-", the new blue coil is not... that I can see from the engine bay anyway. I have the wiring diagram, and can see the green wire(from condensor) goes to one side and the 2 other wires go to the other side... but which coil side is for which wires? I *think* I have it right, but want to double check before I start it up... |
Aaron Cox |
Aug 17 2005, 09:54 AM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
Black and purple wire is your tach.... goes to the neg side.
Switched Current to coil is in a black and ??? wire..... and it goes to the + |
tat2dphreak |
Aug 17 2005, 01:14 PM
ok, is there an easy way to determine which side of the coil is which? if it's not labeled?
haynes shows 3 wires... the green on to the dizzy one one side, the other 2 on the other side... |
mightyohm |
Aug 17 2005, 01:15 PM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
Pull it out, it's probably labeled somewhere.
tat2dphreak |
Aug 17 2005, 01:19 PM
yea, I was just now thinking that maybe the marks are hidden. |
ArtechnikA |
Aug 17 2005, 01:27 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
they will definitely be labelled *somehow*
usually + and - otherwise, it'll have the DIN codes - 15 is + the other one (Terminal 1?) is minus... |
tat2dphreak |
Aug 17 2005, 01:33 PM
ok, it IS labeled 15 and 1... thanks! so, the green wire and black/??(not purple) go to the negative side? |
ArtechnikA |
Aug 17 2005, 01:38 PM
i'm not getting sucked into the color thing, 'cause i can't see your car :-) points and tach (which i thought should be black with violet tracer) connect to Terminal 1; switched +12V connects to Terminal 15. that's if you're using stock points. if you're using some other kind of points replacement module or CD ignition, i'm not even gonna suggest... |
Aaron Cox |
Aug 17 2005, 01:47 PM
black/Purple TACH wire goes to - side....
Green wire from points goes to neg side... 3 - 2 = 1 wire left.... yup. whatever color it is...goes to the + side v (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) |
tat2dphreak |
Aug 17 2005, 01:54 PM
ok, cool
yes, right now, it still has points, I'll sync the carbs with the 009 that's on there, then put in the 050 with a compufire... thanks!! |
Aaron Cox |
Aug 17 2005, 02:01 PM
Unilite (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
tat2dphreak |
Aug 17 2005, 02:42 PM
it's on the list, for when I get rich as shit! (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 03:27 PM |
