| DdHavtech |
Aug 29 2023, 09:05 AM
Newbie ![]() Group: Members Posts: 8 Joined: 21-March 18 From: Ellicott City, MD Member No.: 21,993 Region Association: None
| GregAmy |
Aug 29 2023, 09:14 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,659 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
Is it transaxle or engine oil?
Is it only the right side? Looks like axle shaft seal. If both, and transaxle oil, input shaft seal. If engine oil...crankshaft seal. |
| Root_Werks |
Aug 29 2023, 09:16 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,964 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
You can smell gear oil vs engine oil. See if you can give it the sniff test.
Flying oil while driving can be tough to track down. The engine looks pretty much dry, rear main seal or farther back. |
| brant |
Aug 29 2023, 09:54 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,183 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
could be a main seal in the engine... could be the front (main) seal in the transmission
both require dropping at least the trans to replace. you'll know if your clutch disc is wet when you get it apart but I've had oil fly everywhere on the road so best to clean it well... short drives and see where it is coming from as it starts to drip... before it covers everything |
| emerygt350 |
Aug 29 2023, 10:01 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,539 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Looks like the gasket in the cv might be gone. Could be cv grease.
| rhodyguy |
Aug 29 2023, 10:09 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
RMS. No way a cv contains that much lube. What ever it is, it’s been leaking a long time. The mess is pretty far forward on the trans.
| JeffBowlsby |
Aug 29 2023, 10:18 AM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,245 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Take it to a coin op car wash and then immiedately begin to look for the fresh oil source.
| technicalninja |
Aug 29 2023, 10:47 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
Take it to a coin op car wash and then immiedately begin to look for the fresh oil source. (IMG:style_emoticons/default/agree.gif) I also use Tracerline UV dies. A simple UV flashlight (Walmart $10) will work just fine. Better yet, the Tracerline TP1300 is the BRIGHTEST UV light source I've ever seen. Look directly at it and it will give you flash blindness. You HAVE to use the yellow glasses with it. It's bad-assed and what I use almost exclusively finding AC refrigerant leaks. |
| 930cabman |
Aug 29 2023, 12:18 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,640 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
How long has this been acting up? just since your recent repair? |
| emerygt350 |
Aug 29 2023, 01:48 PM
It looks pretty old...
| porschetub |
Aug 29 2023, 02:25 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,091 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
RMS. No way a cv contains that much lube. What ever it is, it’s been leaking a long time. The mess is pretty far forward on the trans. (IMG:style_emoticons/default/agree.gif) bottom of engine looks reasonably clean expect the RMS has been leaking for some time ,lower it closer to the ground and put a sheet of cardboard under the bell housing area and run it up till warm, I would say it will drip out the opening fairly soon. Think you will find other leaks also but reckon this is the primary cause . Good luck sorting it,cheers. |
| porschetub |
Aug 29 2023, 02:26 PM
| Aerostatwv |
Aug 29 2023, 03:01 PM
Member ![]() ![]() Group: Members Posts: 151 Joined: 13-July 11 From: WV Member No.: 13,315 Region Association: MidAtlantic Region
Mine looked similar. Dropped the motor and transaxle and put all new seals in. So far, after 1.5 years, no leaks..
| Shivers |
Aug 29 2023, 03:09 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,367 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Giving it the taste test will tell you a lot. (IMG:style_emoticons/default/biggrin.gif) They smell completely different, engine oil out of a good running engine will have a mild smell, if any. Trans fluid has a strong gamey smell...Rotten dinosaur maybe. You’ll still have to drop at least the trans, but at least you’ll know what to buy.
I’d drop the whole thing and do some house cleaning while I was in there. |
| r_towle |
Aug 29 2023, 05:40 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Trans axle shaft seals (o-ring) and cv joint gasket and probably a new boot too.
Look at the housing at the trans….it’s soaked |
| bobboinski |
Aug 29 2023, 06:38 PM
Member ![]() ![]() Group: Members Posts: 200 Joined: 23-April 16 From: Petaluma Member No.: 19,929 Region Association: Northern California
Speedometer drive is at least part of it.
| 930cabman |
Aug 30 2023, 04:59 AM
| Front yard mechanic |
Aug 30 2023, 05:36 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,444 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None
Oop
| technicalninja |
Aug 30 2023, 07:13 AM
Coin operated car wash?wtf is that Decades ago you could drive up to a car wash and wash your car for a quarter! Now it takes a whole roll... You rip you couch apart, dig under the seats and center console in your car and maybe find enough quarters for 5 minutes of high-pressure action. Where I'm at, if the owner of the self-serve car wash saw you cleaning the undercarriage or individual greasy parts, they will have a SHIT FIT. You will have a problem on your hands... I've taken a jack and jack stands before to allow serious undercarriage cleaning, but I ONLY do this deep night now. In the big cities you will often find low class drug dealers frequenting a coin operated car wash. I can't count the number of times I've been offered drugs at one of these past midnight. I've always been armed when doing this stuff for just this reason. When I build my big shop on my property I'm planning an old used side post lift outside, under a tall carport, to do this type of work... |
| wonkipop |
Aug 30 2023, 07:55 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,489 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
Coin operated car wash?wtf is that Decades ago you could drive up to a car wash and wash your car for a quarter! Now it takes a whole roll... You rip you couch apart, dig under the seats and center console in your car and maybe find enough quarters for 5 minutes of high-pressure action. Where I'm at, if the owner of the self-serve car wash saw you cleaning the undercarriage or individual greasy parts, they will have a SHIT FIT. You will have a problem on your hands... I've taken a jack and jack stands before to allow serious undercarriage cleaning, but I ONLY do this deep night now. In the big cities you will often find low class drug dealers frequenting a coin operated car wash. I can't count the number of times I've been offered drugs at one of these past midnight. I've always been armed when doing this stuff for just this reason. When I build my big shop on my property I'm planning an old used side post lift outside, under a tall carport, to do this type of work... 'm (IMG:style_emoticons/default/biggrin.gif) and 'm (IMG:style_emoticons/default/hands.gif) coz whatever is going down in the usa is gonna be going down here in 10 years time and i'm not looking forward to going to the pressure wash armed at midnight. (IMG:style_emoticons/default/blink.gif) ---- back to topic. if thats a rear main seal your clutch would be slipping i tend to think. the photo is a bit far back to really tell where the exxon valdez disaster is originating from but she sure is an environmental law suit. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 30th April 2026 - 11:11 AM |
