Mystery Wires Continued |
DennisV |
Sep 3 2023, 06:59 AM
Member Group: Members Posts: 473 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
I have another couple mystery wires.
The first I assume is not original previous owner hijinks. It is cut at both ends. One end found near the shifter. It runs from there, through the tunnel to the engine compartment, along the firewall. The other end cut near the oil filter. It looks like a type of coax cable. Perplexed as to what it would be for. (IMG:style_emoticons/default/confused24.gif) I still have this brown / white stripe wire with spade connector that lands near the shifter. It is wrapped in the factory bundle tape and appears original. I can't find it on the wiring diagram or figure out what it is for. Insight appreciated. (IMG:style_emoticons/default/blink.gif) |
76-914 |
Sep 3 2023, 09:24 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Maybe it was rerouted in error and is possibly the one that is supposed to go up to the courtesy lamp behind the back pad? (IMG:style_emoticons/default/confused24.gif)
FlacaProductions |
Sep 3 2023, 10:29 AM
Senior Member Group: Members Posts: 1,598 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
The coax - maybe a lead for a CB antenna?
914_7T3 |
Sep 3 2023, 10:30 AM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,853 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
It’s for the hot air blower in the engine compartment. I believe it connects to the hot air lever with the red handle next to the shifter.
Superhawk996 |
Sep 3 2023, 10:32 AM
914 Guru Group: Members Posts: 5,869 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
The coax - maybe a lead for a CB antenna? (IMG:style_emoticons/default/agree.gif) 1970s Smokey detector. RG-58 =CB cable. Get that outta’ there and seal whatever hole they cut to get it there. |
DennisV |
Sep 3 2023, 07:25 PM
FlacaProductions |
Sep 3 2023, 07:53 PM
It's an additional electrical connection - as opposed to the physical connection of those two cables. You pull the red lever up, it physically pulls those two cables opening the warm air valves. when you pull it all the way up (or nearly) it grounds the connection to the heater blower that sits on the drivers side next to the relay board, turning it on.
DennisV |
Sep 4 2023, 05:24 PM
It's an additional electrical connection - as opposed to the physical connection of those two cables. You pull the red lever up, it physically pulls those two cables opening the warm air valves. when you pull it all the way up (or nearly) it grounds the connection to the heater blower that sits on the drivers side next to the relay board, turning it on. Fascinating! Can you share a photo of where that cable terminates? I looked at our lever but didn't see anything that looked like it was meant for an electrical connection. |
Superhawk996 |
Sep 4 2023, 05:30 PM
FlacaProductions |
Sep 4 2023, 07:43 PM
sixnotfour |
Sep 4 2023, 09:07 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
sportamtic shifter
Root_Werks |
Sep 5 2023, 11:33 AM
Village Idiot Group: Members Posts: 8,326 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
914-6's didn't have the electric heater blower motor anyway.
My guess is for optional sporto trans. |
FlacaProductions |
Sep 5 2023, 12:46 PM
oooooh - didn't catch that this was a -6 but should have from the first pic....
Dave_Darling |
Sep 6 2023, 10:56 PM
Any wire running along the main harness that is not inside the vinyl tubing with the rest of the harness is an add-on of some kind.
Check the wiring diagram for your year/model to see what brown/white wires are present. See if any of those might wind up with a connector near the shifter. --DD |
ClayPerrine |
Sep 7 2023, 05:26 AM
Life's been good to me so far..... Group: Admin Posts: 15,490 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
It could be the wiring for the heated rear window. It was a separate harness.
Lo-Fi Version | Time is now: 29th May 2024 - 02:58 AM |
