D-jet Ecu plug terminal...is this the correct one ?, learning about my D-jet, not so scary afterall...but still confusing |
Frankvw |
Sep 6 2023, 07:52 AM
working on my first 914 ! Group: Members Posts: 651 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
Hi all, I am looking at injection components and try to learn about the L-jet and D-jet injection a bit. D-jet on the 914 and L-jet on the VW T2B.
I learned already a lot from the forum, internet and from several people. So, now it is less scary, I wanted to take next steps and work with it. I do have a question about the D-jet on my 1973 1.7 914. I got the terminals off the 2, 3, 4 and 5 pin connectors on the injection harness, and those terminals look like terminals I have seen before...pretty standard. Now I removed a terminal from my Djet ECU plug, and it looks like attached pic. That is quiite differnt than what I have ever seen and for sure differet than Ljet has. Is this what should be in there from factory on 1.7 D-jet ? Or was there a PO that did this ? Thanks for your feedback and wisdom Frank |
mgphoto |
Sep 6 2023, 08:55 AM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
The ECU is an edge connector board, those look correct, but I would like to see the way the are mounted within the plastic cable connector.
Frankvw |
Sep 6 2023, 08:58 AM
Hi, thansk for feedback !
I also got confirmation from one of the harness gurus that it is the correct connector indeed. |
Dave_Darling |
Sep 6 2023, 10:52 PM
You could do worse than talking to Jeff Bowlsby about your questions.
https://bowlsby.net/914/WiringHarnesses/ --DD |
Frankvw |
Sep 6 2023, 11:08 PM
You could do worse than talking to Jeff Bowlsby about your questions. https://bowlsby.net/914/WiringHarnesses/ --DD Guess who the harness guru was I mentioned ...... ;-) |
Lo-Fi Version | Time is now: 3rd June 2024 - 11:24 AM |
