> Fuel Pump Direction, Redline
stoneman30hotmail
post Sep 17 2023, 02:10 PM
Does this pump have a prefered direction? https://www.carburetion.com/products/ProductDetails.aspx...
I can't find directions or indications on it. I'm not getting fuel, but don't know if it's this or the filter or the pressure regulator. It did get stuck when I had it before the filter but then I freed it by reversing polarity. Now I have the filter first. If I reverse polarity now I can hear bubbles in the fuel tank.
Replies(1 - 19)
sixnotfour
post Sep 17 2023, 02:52 PM
The Large Terminal is Ground, Small Terminal is Positive on this Pump.
stoneman30hotmail
post Sep 21 2023, 03:32 PM
I think in the end it was just a bubble in the fuel line.
stoneman30hotmail
post Oct 3 2023, 04:20 AM
Now on finally driving this I got stuck with vapor lock. After sitting a while I could drive off. It's not terribly hot out and this was later in the day. So I'm wondering if the fuel pump is making a lot of heat. In all the playing around above "bubbles" maybe does mean fuel vapor just from the pump heat without the engine running. That may also explain why some cars have problems in the rear location while others don't. Does that fit anyone else's experience?
So now I'm not sure if I should relocate the pump thinking it's going to overheat nomatter where it is. Maybe needs a new pump?
mate914
post Oct 3 2023, 05:06 AM
Matt
QUOTE(stoneman30hotmail @ Oct 3 2023, 06:20 AM) *
Can you show use a picture of your fuel pump installed. I have never seen a fuel pump get hot and vapor lock. I have seen carbed engines that run hot and vapor lock. Things that cause vapor lock. Poor routing of fuel lines, timing, compression too high, engine cooling tins not install, engine covered in 50 year old grim and blocking cooling fins.
Hope this helps,
Matt
rhodyguy
post Oct 3 2023, 10:51 AM
Post a picture of the pump mounted. Is hot air blowing on the pump? To what degree has the fuel system been renewed?
stoneman30hotmail
post Oct 3 2023, 11:16 AM
It happened again after like a five mile drive. I felt around and nothing is really that hot.
I've been working on the car for a year. So these are the first drives. As part of the redo I've replaced the plastic tunnel lines with metal and all new hoses elsewhere - er may have reused a couple short pieces.
New fuel filters.
rhodyguy
post Oct 3 2023, 11:32 AM
Is it a dies while driving thing or no restart after sitting while hot? What’s the story with the folded over piping piece near the firewall exit point?
stoneman30hotmail
post Oct 3 2023, 12:18 PM
QUOTE(rhodyguy @ Oct 3 2023, 01:32 PM) *
Dies while driving.
I think by folded over piping piece you mean the return line. But it is connected to the tank. That's just there in case it would be converted over to higher pressure fuel pump I guess.
rhodyguy
post Oct 3 2023, 12:43 PM
But the line runs from the fold to the filter inlet? The metal line is capped and goes nowhere.
mate914
post Oct 3 2023, 12:46 PM
Matt
QUOTE(stoneman30hotmail @ Oct 3 2023, 02:18 PM) *
Dies while driving.
@stoneman30hotmail
Check the fuel tank sock inside the tank for clooging.
Fuel pump goes to big fuel line, your connected to the return.
Having a fuel return with low pressure is always a good thing because of how the fuel returns to the tank for reserve fuel.
I think your running out of gas......
Matt (IMG:style_emoticons/default/flag.gif)
rhodyguy
post Oct 3 2023, 12:52 PM
The in tank filter sock would be on the factory supply line. I don’t think the sock is currently in play. The folded return (now supply) line could be well fouled with tank debris backed up at the fold. Somewhat of a mess.
stoneman30hotmail
post Oct 3 2023, 01:03 PM
QUOTE(rhodyguy @ Oct 3 2023, 02:43 PM) *
Right, it's these https://www.pelicanparts.com/cgi-bin/smart/...=PEL-SS914-7074
Are you saying both are needed for some reason? Not sure where I'd put it off the carburator. Or I connected the wrong one to the pump? I got a couple fuel baths rearranging things to begin with. There is fuel comming out the smaller diameter one after putting 1 gal in the tank. So I'm pretty sure I got the feed line going to the filter.
mate914
post Oct 3 2023, 01:06 PM
Matt
QUOTE(stoneman30hotmail @ Oct 3 2023, 03:03 PM) *
Might want to double check that. Large line coming out of tank is the feed. Small is the return.
Matt
rhodyguy
post Oct 3 2023, 01:16 PM
The hardline link is for a set. Only one is on your car.
Is it carbs (with an s) or carb as in a single?
Long story short, the fuel pump supply line is connected to the folded over and now kinked return line.
stoneman30hotmail
post Oct 3 2023, 02:01 PM
Ok, good tip, larger line is feed. (IMG:style_emoticons/default/wacko.gif) Then I need some kind of reducer thing to get to the filter unless I get that in the filter..
Another clue: If I blow into the line from the carb, the pump works for a while. That allowed me to take the first drive and then I did it again got another 4 miles and now again and I got 1/2 mile home. At first I didn't think that was the temporary fix, but maybe was. Maybe I need another fuel filter already also?
stoneman30hotmail
post Oct 4 2023, 05:48 PM
Heres a better picture of the bends. They're as they came.
Now with the right line as supply.
But it still doesn't work. A few tests run:
1. Disconnect large pipe - lots of fuel drop out. I probably let out 1/2 gallon in 15 seconds. So not the sock.
2. Disconnect line at carburator, run pump (key on) - pumps continuous (1/2 gallon fast) . So not a clog.
3. Idle engine - starts at 2 psi at gauge, stalls after 5-10 min, no pressure at fuel gauge, pump still buzzing
(after draining some fuel through system)
4. Leave pump to run, engine off, no flow - fuel pressure gauge shows 2 psi after regulator but pressure drop to 0 eventually (5-10min) pump still buzzing
ChrisFoley
post Oct 4 2023, 06:17 PM
I am Tangerine Racing
bad pump
stoneman30hotmail
post Oct 5 2023, 04:37 AM
Any recommendations? I saw summit racing has a $40 option. But I have Napa, Autozone, Orielly and Advance Autox2 within 5 miles.
mate914
post Oct 5 2023, 04:58 AM
Matt
QUOTE(stoneman30hotmail @ Oct 5 2023, 06:37 AM) *
LN Engineering has the best price and shipping was fast.
$52.49
Matt
- Lo-Fi Version Time is now: 9th May 2025 - 04:26 PM
