DennisV |
Senior Member ![]() ![]() ![]() Group: Members Posts: 607 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California ![]() ![]() |
I removed the bushings from the front strut shock mounts (aka support mount, camber plate). Now I'm a bit confused on the correct bushing and the finish of the mount plate for a 1970 914-6.
What I removed
Looking for parts online, that bushing sold separately is listed as '71-89. While sold a few places, I am seeing Elephant as the only current manufacture. If you buy a whole new mount with bushing, they are gold. By chance, did the bushing differ depending on whether Boge or Koni were installed? I only see a single part number in the PDF catalog (911 341 018 00). (IMG:style_emoticons/default/huh.gif) Based on the condition of ours, I am guessing they are original. Can anyone confirm? ![]() |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,876 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
You can buy two piece rubber mounts that install easy.
What you have looks original to me. |
Geezer914 |
Geezer914 ![]() ![]() ![]() Group: Members Posts: 1,922 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States ![]() ![]() |
I think I bought a set of 2 piece bushings from PMB Performance.
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,743 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
The finish of the mount is satin black.
After installation and alignment the area around the top of the mount in the trunk is then spackled with a thick, black, tar like material. This is not seen on any 914 other than the 914 6. (seen on 911s too) Attached thumbnail(s) ![]() ![]() |
DennisV |
The finish of the mount is satin black. After installation and alignment the area around the top of the mount in the trunk is then spackled with a thick, black, tar like material. This is not seen on any 914 other than the 914 6. (seen on 911s too) Thanks for sharing. That is good news. Ours is still has the material around where the mount plate was installed. Original paint underneath! ![]() |
friethmiller |
Senior Member ![]() ![]() ![]() Group: Members Posts: 876 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region ![]() ![]() |
I'd recommend hitting each nut with a bit of weld to help secure it - just in case. I've had a nut come loose on me during the install process (after powder-coating (IMG:style_emoticons/default/sad.gif) ). It would have been so much easier if I had done this before reconditioning the mounts.
Lo-Fi Version | Time is now: 9th May 2025 - 04:56 PM |
