Miniwerks |
Newbie ![]() Group: Members Posts: 25 Joined: 11-March 23 From: Fair Oaks, CA Member No.: 27,219 Region Association: Northern California ![]() |
I removed my bumper and plastic headlight surround to see if there is a way to adjust the small piece in my photos. It appears there is no adjustment, just rubber grommets that hold both ends in place and they have some play. The one furthest to the right, touching driver side fender is loose so the gap between headlight cover is greater than the left attachment point. You can see second photo with light pressure pushing it back. Are these rubber grommets easy to change out? I did not want to pull one out until I get some insight.
Attached image(s) ![]() ![]() |
StarBear |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,120 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States ![]() ![]() |
Was the drivers front quarter panel ever replaced? Many of the aftermarket ones didn’t fit real well.
Miniwerks |
windforfun |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,054 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None ![]() ![]() |
That's better than average, but it shouldn't be loose for sure.
(IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) |
Shivers |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,982 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California ![]() |
It may be a bit twisted. Maybe a clockwise twist on the right and a counter clockwise twist on the left. Small moves
Miniwerks |
Upon further inspection, the rubber grommet is in fact toast so will source new.
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,360 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
If you are bold, you can adjust the position by bending the metal "legs" on the eyebrow.
burton73 |
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,823 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California ![]() ![]() |
Lo-Fi Version | Time is now: 9th May 2025 - 04:49 PM |
