Petal box, are all covers that go behind petals the same |
Delaware914 |
Sep 25 2023, 10:05 AM
Newbie Group: Members Posts: 6 Joined: 10-February 23 From: Delaware Member No.: 27,155 Region Association: MidAtlantic Region |
afternoon all,
i am new to this ... and am having a heck of the time with brake lights i have had the switch changed, still no luck.. i have a guy willing to look at it tomorrow and he asked if i knew anything about this cover perhaps if there was a drawing ?? So, what is the experience.. 73 914" appreciate all info ! Kerry |
BillJ |
Sep 25 2023, 10:17 AM
Senior Member Group: Members Posts: 1,111 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
The pedal cluster has a standard board that includes a throttle pedal stop that is adjustable and a clutch pedal bumper (also adjustable). There are aftermarket variants but they are the same as provided by the factory. The board should have nothing to do with improperly functioning brake lights. If you changed the switch already then it is probably electrical....
Mikey914 |
Sep 25 2023, 11:10 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yep, the switch is set to "close" as soon as the pedal moves. Takes some adjustment. Not too hard if everything is working.
rhodyguy |
Sep 26 2023, 07:08 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Which side of the disc on the MC rod is the switch arm on? Front or rear of the disc? P.110 Fig 8.4. of your Haynes. The switch must be adj correctly.
930cabman |
Sep 26 2023, 09:07 AM
Advanced Member Group: Members Posts: 3,144 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
The brake light system is pretty basic, unless it's not working. Do you have a Haynes or Clymer workshop manual? |
Delaware914 |
Sep 26 2023, 12:05 PM
The pedal cluster has a standard board that includes a throttle pedal stop that is adjustable and a clutch pedal bumper (also adjustable). There are aftermarket variants but they are the same as provided by the factory. The board should have nothing to do with improperly functioning brake lights. If you changed the switch already then it is probably electrical.... Had it working when the cover was removed, but now its back to not working.. could be the adjustment thanks for the comment |
Delaware914 |
Sep 26 2023, 12:06 PM
mepstein |
Sep 26 2023, 12:07 PM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Delaware914 |
Sep 26 2023, 12:08 PM
(IMG:style_emoticons/default/welcome.png) The brake light system is pretty basic, unless it's not working. Do you have a Haynes or Clymer workshop manual? no i do not, will get one for the next problem (IMG:style_emoticons/default/smile.gif) |
930cabman |
Sep 26 2023, 12:10 PM
(IMG:style_emoticons/default/welcome.png) The brake light system is pretty basic, unless it's not working. Do you have a Haynes or Clymer workshop manual? no i do not, will get one for the next problem (IMG:style_emoticons/default/smile.gif) Being 1/2 century young, there will be another .... well you know. But the guys/gals here are always willing to assist |
rhodyguy |
Sep 26 2023, 05:03 PM
If you owned a Haynes troubleshooting the brake light system would be a breeze. The next problem is down the road a bit. Prepare for it now.
Lo-Fi Version | Time is now: 8th June 2024 - 02:27 AM |
