914 Rubber Latch Rebuild Kits, Anyone know where these washers go? |
76-914 |
Sep 28 2023, 01:31 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Ishley |
Sep 28 2023, 02:10 PM
Member Group: Members Posts: 101 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest |
So you need a special kind of washer clip.... I got mine at McMaster Carr... but of course you have to buy a box of them. Everything else I tried didn't work until I found a post here that mentioned these clips.
https://www.mcmaster.com/catalog/96415A170 Push-on External Retaining Rings, Black Oxide Steel, for 6 mm OD, 16 mm OD |
76-914 |
Sep 28 2023, 02:25 PM
So you need a special kind of washer clip.... I got mine at McMaster Carr... but of course you have to buy a box of them. Everything else I tried didn't work until I found a post here that mentioned these clips. https://www.mcmaster.com/catalog/96415A170 Push-on External Retaining Rings, Black Oxide Steel, for 6 mm OD, 16 mm OD That's good to know. I have the original and will re-use it if necessary. Just found it odd that there are 2 washers in the kit that may not have a purpose. (IMG:style_emoticons/default/confused24.gif) |
Ishley |
Sep 28 2023, 02:47 PM
Call 914 Rubber... Mark will know. They've been helpful to me.
76-914 |
Sep 28 2023, 05:48 PM
I think I figured it all out once removed my head from my arse. I had the left hook on the right side. (IMG:style_emoticons/default/headbang.gif) Now I know what that roll pin's purpose is. One side was wobbly but I still had my rivet guns and sets so that was just a matter of re-setting the rivet. That lower roll bar cover fits very nicely. Now I just need to figure out what and where to trim the latch cover on this ver.1 lower roll bar cover. (IMG:style_emoticons/default/piratenanner.gif)
Mikey914 |
Sep 28 2023, 07:10 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Sorry I didn't get to this right away. I had started a tutorial, I'll post up here once I get completed.
Mark |
bdstone914 |
Sep 28 2023, 10:05 PM
bdstone914 Group: Members Posts: 4,529 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@76-914
date='Sep 28 2023, 04:48 PM' post='3104635'] I think I figured it all out once removed my head from my arse. I had the left hook on the right side. (IMG:style_emoticons/default/headbang.gif) Now I know what that roll pin's purpose is. One side was wobbly but I still had my rivet guns and sets so that was just a matter of re-setting the rivet. That lower roll bar cover fits very nicely. Now I just need to figure out what and where to trim the latch cover on this ver.1 lower roll bar cover. (IMG:style_emoticons/default/piratenanner.gif) [/quote] I just ordered 100 clips the hooks for the katches i restore. These are the best ones to use. I found that other clips can pop off under tension. The problem is the worn post and canse the hook to push out when you clamp the top down. I can send you a few as they should be here tomorrow. Attached thumbnail(s) |
76-914 |
Sep 29 2023, 09:05 AM
Sounds good. Thx.
Lo-Fi Version | Time is now: 31st May 2024 - 08:57 PM |
