Using a 912 fuel gauge |
RFoulds |
Sep 28 2023, 03:58 PM
Green Teen 66 Group: Members Posts: 837 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region |
I have a 912 fuel gauge in the dash. The sender wires match up, the low fuel light works properly. But the gauge itself is just pinned to the Full end.
Is the sender sending a higher watt or amperage than the gauge wants? Anyway to find the correct values so I can correct for it? |
Root_Werks |
Sep 28 2023, 04:05 PM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
I think the ohm range isn't only wrong, but reversed. Like a Bug sending unit.
RFoulds |
Sep 28 2023, 04:33 PM
I think the ohm range isn't only wrong, but reversed. Like a Bug sending unit. Well that might cause issues. (IMG:style_emoticons/default/sad.gif) |
914Sixer |
Sep 28 2023, 06:13 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Need to see gauge pictures. 914 fuel works down right to left, 911/912 works up left to right.
RFoulds |
Sep 28 2023, 08:23 PM
Morrie |
Sep 29 2023, 11:56 AM
Member Group: Members Posts: 181 Joined: 8-October 07 From: Cedar Park, Texas Member No.: 8,198 Region Association: Southwest Region |
I have a 912 fuel gauge in the dash. The sender wires match up, the low fuel light works properly. But the gauge itself is just pinned to the Full end. Is the sender sending a higher watt or amperage than the gauge wants? Anyway to find the correct values so I can correct for it? The 912 and 914 use the same sending unit (I have a 912 and a 914) and the gauges are interchangeable. I agree that the wires may be swapped in your case. Here's my gauge with the 912 fuel installed. (John Bell's work of course) |
RFoulds |
Sep 30 2023, 07:24 AM
Great info. Thank you.
Lo-Fi Version | Time is now: 11th June 2024 - 02:46 PM |
