Need Parts Pricing Help, Asking for a friend...honest! |
GregAmy |
Oct 18 2023, 07:42 AM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I've got an autocrosser buddy who's looking to sell off some parts. They have a /6 (C Mod?) and the family is looking to sell off a rather large collection of accumulated parts.
Now, I know we all hate these thread; I do, too. What I'm actually hoping for is that someone will see this list and DM or email me (grega at pobox com) a solid reasonable price list she should ask for these. Even better, maybe someone wants to make an offer on the whole lot ( @mepstein , you're nearby...?) She lives near Harrisburg PA. What I really don't want is argumentatation and debate. If it gets ugly I'll just kill the thread...I know, I know, I know, but I'm just looking to provide some guidance on this. And I have no vested interest in this as I'm not taking a cut...truly just trying to help a friend. The hardest part for me is avoiding buying all this stuff myself... Guidance appreciated. - GA 1970 Porsche 914 Shifter 1970 Porsche 914/6 Crankshaft 1970 Porsche 914/6 Engine Shroud (2) 84mm pistons (6) 85 mm pistons (6) and barrels (5) Clutch disk Clutch Pressure Plate Distributor Early 911/912 Clutch Fork (2) Intermediate Shaft JE Series 96 wrist pin (1) KONI Shocks (rebuildable) Megaphone supports Mom Racing Steering Wheel - 10" Oil Cooler Oil pickup tubes (2) Oil Pressure Relief Piston Oil pump (2) Pair of 6-cylinder Porsche Carburetor Rain Hats, flat finish Pair of 6-cylinder Porsche Carburetor Rain Hats, textured finish Pair of mufflers Porsche 901 A Gear Porsche 901 Gear F2 Porsche 901 Gear F3 Porsche 901 gearbox open differential Porsche 901 KA Gearset Porsche 901 N Gear (3) Porsche 901 Transmission side plate (3) Porsche 901 V Gear (2) Porsche 901 V Gearset Porsche 901 Z Gear Porsche 901 ZB Gear (2) Sump Cover (2) Sump Screen Temperature sender (2) Trumpets (3 sets of 6) |
930cabman |
Oct 18 2023, 05:13 PM
Advanced Member Group: Members Posts: 3,148 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
$3.k
rudedude |
Oct 19 2023, 06:53 AM
Senior Member Group: Members Posts: 511 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest |
I probably have most of what is listed and I would love to get 3K for them.
Superhawk996 |
Oct 19 2023, 07:13 AM
914 Guru Group: Members Posts: 5,903 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I’m sort of clueless on trans gear pricing (some sets are outrageous) and what’s desirable for racing but personally I can’t see $3k there for used parts unless someone needs all of it and is willing to pay top dollar for all of it since not stated NOS or new, I’m assuming all are used or undocumented lightly used parts?
The crankshaft is probably the most valuable thing there? And I’d be assuming it needs to be reground, heat treated, etc and that isn’t cheap. Plus it’s a 2.0l so unless someone building a stock 2.0l /6 where is the demand? Not cheap to have crank work done. Oil cooler - I see it as used / questionable / contaminated / potentially leaks - at least $120 to clean and test one last time I had one done. Given it’s $10k-$15k to rebuild a /6 I’m not likely to be reusing oil coolers though lots of folks do. Unmatched pistons & cylinders represent a liability to me (my opinion) and when rebuilding an engine I’m far more likely to just replace with new parts. The exception might be if all are Mahle and in exceptional condition and were labeled matched so parts aren’t just all mixed up (ie basket case engine). Oil pumps? 3 rib early pumps I assume? Most folks are looking for the later 4-rib aluminum Carrera pumps. And loose pickup tubes? Those aren’t usually seperated from pumps so I’m sort of assuming pumps have been disassembled / modified for racing use? Koni shocks - sure they are rebuildable but that costs as much as a new pair so unless some one is an old Koni red fanatic - where’s the money? Not trying to be overly negative but to get top dollar it all needs to be “parted out” and sold piece by piece. I honestly could use probably use at least 1/2 the parts there and I wouldn’t go more than $1k for a lot like that sight unsen - pictures might change that by 50% on the up side? Just an opinion from a cheap bastard. |
mepstein |
Oct 19 2023, 08:12 AM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I’m sort of clueless on trans gear pricing (some sets are outrageous) and what’s desirable for racing but personally I can’t see $3k there for used parts unless someone needs all of it and is willing to pay top dollar for all of it since not stated NOS or new, I’m assuming all are used or undocumented lightly used parts? The crankshaft is probably the most valuable thing there? And I’d be assuming it needs to be reground, heat treated, etc and that isn’t cheap. Plus it’s a 2.0l so unless someone building a stock 2.0l /6 where is the demand? Not cheap to have crank work done. Oil cooler - I see it as used / questionable / contaminated / potentially leaks - at least $120 to clean and test one last time I had one done. Given it’s $10k-$15k to rebuild a /6 I’m not likely to be reusing oil coolers though lots of folks do. Unmatched pistons & cylinders represent a liability to me (my opinion) and when rebuilding an engine I’m far more likely to just replace with new parts. The exception might be if all are Mahle and in exceptional condition and were labeled matched so parts aren’t just all mixed up (ie basket case engine). Oil pumps? 3 rib early pumps I assume? Most folks are looking for the later 4-rib aluminum Carrera pumps. And loose pickup tubes? Those aren’t usually seperated from pumps so I’m sort of assuming pumps have been disassembled / modified for racing use? Koni shocks - sure they are rebuildable but that costs as much as a new pair so unless some one is an old Koni red fanatic - where’s the money? Not trying to be overly negative but to get top dollar it all needs to be “parted out” and sold piece by piece. I honestly could use probably use at least 1/2 the parts there and I wouldn’t go more than $1k for a lot like that sight unsen - pictures might change that by 50% on the up side? Just an opinion from a cheap bastard. I think Phil is on point. |
gereed75 |
Oct 19 2023, 09:55 AM
Senior Member Group: Members Posts: 1,260 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Everything I am about to say here you probably already know, but maybe one more opinion will help your buddy make a decision.
There are some pieces here that have some value to a very limited market: Engine shrouds. Mufflers Oil cooler Gears All could be sold over time for "top dollar" on here or Pelican with clean up/pictures etc etc - you know the deal. In the end that might net $2000. The rest would make a fun day giving it all away at the spring Carlisle swap, maybe netting another $1000 if lucky. At least maybe half of it gets back in the community that way. Then you give away or scrap the rest Just not a lot of value in this kind of small hoard any more. |
sixnotfour |
Oct 19 2023, 07:50 PM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
GregAmy |
Nov 4 2023, 07:24 AM
Quick follow up. This should probavbly get moved to anothe appropriate sub-forum, but based on the feedback here I recommended she leverage eBay to part it all out.
Here's a link to her...channel? store? and she offered to me that if anyone here is looking for something specific from her list that she has not listed on eBay, I can send to you via PM her contact info. Thanks for your patience. - Greg |
Lo-Fi Version | Time is now: 10th June 2024 - 06:36 AM |
