Center Console Gauge Temperature? |
jackspratt |
Oct 21 2023, 12:44 PM
Member Group: Members Posts: 55 Joined: 5-February 22 From: Canada Member No.: 26,315 Region Association: Pacific Northwest |
Hi all,
Was driving around first time. The center console gauge that says temp just comes up to the first white line. Doesn't seem to move past that at all when driving for 1/2 hour or so. Is this normal ? And if not. How do I get it to work or function properly for what it's there for? Talking 1973 dual carbs, 2056 Thanks!!! Attached image(s) |
930cabman |
Oct 21 2023, 05:24 PM
Advanced Member Group: Members Posts: 3,130 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Maybe try an infrared gun pointed at the sump?
Or pull the sender and drop it into boiling water |
jackspratt |
Oct 21 2023, 09:48 PM
jackspratt |
Oct 21 2023, 09:57 PM
Could it be that the thermostat bellows part is missing and that the air flaps are always open and that is why that gauge is not working? It's not hooked up to anything?
Craigers17 |
Oct 22 2023, 05:01 AM
Senior Member Group: Members Posts: 740 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
Based on your type of gauge, if the needle were going a little past the very first/starting line, you could be approaching 180. I'm not sure how cold it is in your part of Canada right now, but I could believe that number is theoretically possible. If it is right at that line or below, ...then something is probably not right.
I'd make sure it is connected. First I would check the connection under the engine where the sender is....here:(in this pic, it may or may not have a cover on it as well) If it is connected there, you might make sure that the gauge itself is connected and trace that back .....I THINK it is spliced into the harness a few feet from the console....but hopefully someone will correct me if I'm wrong. |
stownsen914 |
Oct 22 2023, 07:06 AM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
When you say it goes to the white line ... does it move at all past the "key on" position?
fiacra |
Oct 22 2023, 07:45 AM
Person.Woman.Man.Camera.TV Group: Members Posts: 339 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California |
Maybe try an infrared gun pointed at the sump? Or pull the sender and drop it into boiling water ? To further explain what I believe @930cabman is telling you: You can use a digital infrared thermometer to check temperature at the sump where the temperature sensor is located. Here's an example of one: https://www.homedepot.com/p/Klein-Tools-Inf...1-IR1/313516785 These are also useful for a number of other things, such as checking for uniform brake temperature, checking for heat loss in your home heating ducts, etc... You can pull the sensor and drop it in boiling water to see what the gauge reads. Depending upon the altitude it should read 212 degrees fahrenheit/100 degrees celsius. This thread should help you with checking the thermostat bellows: http://www.914world.com/bbs2/index.php?showtopic=350498 |
930cabman |
Oct 22 2023, 07:59 AM
Could it be that the thermostat bellows part is missing and that the air flaps are always open and that is why that gauge is not working? It's not hooked up to anything? I am not running a thermostat and see my oil temps at 190 for a 20 minute commute daily. Sure it's proper to run the thermo, but in my experience I have had good luck without. These recent cool mornings my defrost is warm within a few minutes. An infrared gun is another tool to diagnose ..... |
Superhawk996 |
Oct 22 2023, 08:04 AM
914 Guru Group: Members Posts: 5,876 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Could it be that the thermostat bellows part is missing and that the air flaps are always open and that is why that gauge is not working? It's not hooked up to anything? Get flaps working 1st. Replace the thermostat bellows, cable, etc, if that is missing. Missing thermostat and flaps that are always open are not good for the engine. They will extend warm up time significantly especially in cold weather. |
Superhawk996 |
Oct 22 2023, 08:05 AM
Could it be that the thermostat bellows part is missing and that the air flaps are always open and that is why that gauge is not working? It's not hooked up to anything? I am not running a thermostat and see my oil temps at 190 for a 20 minute commute daily. Sure it's proper to run the thermo, but in my experience I have had good luck without. These recent cool mornings my defrost is warm within a few minutes. An infrared gun is another tool to diagnose ..... Defrost temps have nothing to do with oil temps and proper warm up. Defrost air is coming off the exhaust heat exchangers. 190 degree oil is too cool for an air cooled engine. 190 is barely registering on oil temp gauge and is consistent with OP symptoms. An engine running too cool is encouraging excessive wear in valve guides, piston slap / scuffing, and increased wear on bearings. |
930cabman |
Oct 22 2023, 08:34 AM
I have never been fond of lazy, but I often am guilty. Will be on the list for this winter.
Superhawk996 |
Oct 22 2023, 10:48 AM
I have never been fond of lazy, but I often am guilty. Will be on the list for this winter. (IMG:style_emoticons/default/beerchug.gif) Your engine will thank you! |
bdstone914 |
Oct 22 2023, 01:34 PM
bdstone914 Group: Members Posts: 4,531 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@jackspratt
If that is where the needle is when the ignition is on you ate not gettimg any signal to the gauge. The sender wire runs from the sender to a connector on the passenger side of the engine bay. If you ground the wire it should peg the gauge hot. If you do not get the needle to move chevk for power and ground at the gauge. |
jackspratt |
Oct 22 2023, 11:35 PM
jackspratt |
Oct 22 2023, 11:38 PM
Based on your type of gauge, if the needle were going a little past the very first/starting line, you could be approaching 180. I'm not sure how cold it is in your part of Canada right now, but I could believe that number is theoretically possible. If it is right at that line or below, ...then something is probably not right. I'd make sure it is connected. First I would check the connection under the engine where the sender is....here:(in this pic, it may or may not have a cover on it as well) If it is connected there, you might make sure that the gauge itself is connected and trace that back .....I THINK it is spliced into the harness a few feet from the console....but hopefully someone will correct me if I'm wrong. Thanks, will check that area. It's 55 usa temp here on the west coast of Canada now. |
jackspratt |
Oct 22 2023, 11:40 PM
Maybe try an infrared gun pointed at the sump? Or pull the sender and drop it into boiling water ? To further explain what I believe @930cabman is telling you: You can use a digital infrared thermometer to check temperature at the sump where the temperature sensor is located. Here's an example of one: https://www.homedepot.com/p/Klein-Tools-Inf...1-IR1/313516785 These are also useful for a number of other things, such as checking for uniform brake temperature, checking for heat loss in your home heating ducts, etc... You can pull the sensor and drop it in boiling water to see what the gauge reads. Depending upon the altitude it should read 212 degrees fahrenheit/100 degrees celsius. This thread should help you with checking the thermostat bellows: http://www.914world.com/bbs2/index.php?showtopic=350498 thanks, ill look into this too |
emerygt350 |
Oct 23 2023, 07:21 AM
Advanced Member Group: Members Posts: 2,132 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Mine works well (verified by infrared) and I have all the flaps etc hooked up. Takes a long time for the oil to get hot in cold weather. However, your gauge shouldn't move when cold and you turn the key on. Am I getting that right? Try grounding the wire and see how the gauge responds.
dr914@autoatlanta.com |
Oct 23 2023, 08:45 AM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
turn the key to on, ground the lead where it attaches to the main harness in front of the battery, and if it flips all of the way, try the same test at the temp plate under the car. If it does not flip the wire is broken if it does flip the temp sender has failed
usually it is the wire Hi all, Was driving around first time. The center console gauge that says temp just comes up to the first white line. Doesn't seem to move past that at all when driving for 1/2 hour or so. Is this normal ? And if not. How do I get it to work or function properly for what it's there for? Talking 1973 dual carbs, 2056 Thanks!!! |
914werke |
Oct 23 2023, 10:29 AM
"I got blisters on me fingers" Group: Members Posts: 10,119 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Add the cover.
North Coast Jim |
Oct 23 2023, 11:47 AM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
Hi all, Was driving around first time. The center console gauge that says temp just comes up to the first white line. Doesn't seem to move past that at all when driving for 1/2 hour or so. Is this normal ? And if not. How do I get it to work or function properly for what it's there for? Talking 1973 dual carbs, 2056 Thanks!!! Is there debris caught on the face of the gauge. It looks like it. If needle gets hung up there it will not register accurately. |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:18 AM |
