Txbentleyboy |
Member ![]() ![]() Group: Members Posts: 73 Joined: 15-October 16 From: Davidson County, NC, USA Member No.: 20,498 Region Association: MidAtlantic Region ![]() ![]() |
Does the engine need to be removed to change the seals?
Any and all thoughts are appreciated! |
GregAmy |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States ![]() ![]() |
I think it's hateful enough of a job trying to do it in the car (you have to remove studs to get the cooler clear) that you may find it worthwhile to remove the drivertain first.
However, when I was removing my drivertain yesterday to get to something behind the fan housing, I looked at it closely and I think that if you remove the sheet metal at the front of the engine, you may have enough space to remove the fan, alternator, and fan housing. From there it's a lot easier work (and would probably make an alternator swap a lot easier, too).. I've never done it in the car, so "caveat emptor". - GA |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,916 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
The simple fact of any mid-engine car is that it is easier to do service with the engine removed from the car.
In less than the time it takes to screw around trying to remove all that stuff working under the car - I could have the engine/trans/heat exchanger/muffler assembly dropped out of the car. Obviously it takes longer to do anything if it’s the first time you ever dropped an engine. At that point it’s all in the open, easy to get to, and less likely to have collateral damage working on stuff. The other thing is that once you’re no longer an engine drop virgin, you don’t need to worry about doing it again, and again, and again. Heck you might even discover you like dropping the engine. |
emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,156 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
Having just done both a seal change while in the car and a whole engine drop with cooler replacement (and a quick 2056 upgrade), I would have to say go for both. Replacing the seals in the car was super easy, and if that is the only thing wrong, go for it. However, I replaced my seals in about an hour only to find that in fact my cooler was cracked...
So, if you are confident it is the seals, just slide the cooler back, pop in the new ones, and call it a day. If you are not sure... well, in the time it took you to replace the seals you could have dropped the engine. I only suggest the easy no drop because if you do drop the engine you could have issues with old brittle wiring etc. |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,183 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
Yes, I would recommend to pull the engine. It's much easier and you are not compromising the repair by working from underneath. Access is key with this job.
rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 3,974 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
I didn't find this job too difficult with the engine in the car. Not everyone has the space to make an engine pull easy.
Try it with the engine in the car first. Worst case scenario is you end up having to pull the engine. |
Big Len |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,747 Joined: 16-July 13 From: Edgewood, New Mexico Member No.: 16,126 Region Association: Southwest Region ![]() |
I did it with the engine in and followed
a tech procedure on Pelican. It is doable. https://www.pelicanparts.com/techarticles/9...ooler_seals.htm |
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,157 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
I did it with the engine in and followed a tech procedure on Pelican. It is doable. Earlier this summer I had reason to do this job. Having never done it "in car" I took the opportunity to learn how easy or hard it was.... IMO pull the motor. (IMG:style_emoticons/default/dry.gif) |
Superhawk996 |
Worst case scenario is you end up having to pull the engine. Worst case is you do all the work attempting to do it in car. But because space, visibility, and access are all limited, you install seals and button it all up. . . . Only to find the seals slipped out of place or got cocked when tightening the cooler back up and couldn’t see the seals - and they are now leaking even worse. Then . . . You get to pull the engine to do it the right way. What’s the old saying ? Never have the time to do it right the 1st time but we always have the time to do it a 2nd? YRMV |
rjames |
Worst case scenario is you end up having to pull the engine. Worst case is you do all the work attempting to do it in car. But because space, visibility, and access are all limited, you install seals and button it all up. . . . Only to find the seals slipped out of place or got cocked when tightening the cooler back up and couldn’t see the seals - and they are now leaking even worse. Then . . . You get to pull the engine to do it the right way. What’s the old saying ? Never have the time to do it right the 1st time but we always have the time to do it a 2nd? YRMV It's not that hard of a job. If I can do it with the engine in, anyone can. Or maybe I didn't do it 'right'. (IMG:style_emoticons/default/rolleyes.gif) |
Superhawk996 |
Worst case scenario is you end up having to pull the engine. Worst case is you do all the work attempting to do it in car. But because space, visibility, and access are all limited, you install seals and button it all up. . . . Only to find the seals slipped out of place or got cocked when tightening the cooler back up and couldn’t see the seals - and they are now leaking even worse. Then . . . You get to pull the engine to do it the right way. What’s the old saying ? Never have the time to do it right the 1st time but we always have the time to do it a 2nd? YRMV It's not that hard of a job. If I can do it with the engine in, anyone can. Or maybe I didn't do it 'right'. (IMG:style_emoticons/default/rolleyes.gif) @rjames I apologize - wasn’t meant as an attack on you. Been around long enough and have seen others get screwed doing it in car. Can it be done that way - yes Would I do it that way - no Again apologize that it came off as a personal attack. |
rjames |
@Superhawk996
I appreciate the note, thanks. It’s all good. (IMG:style_emoticons/default/beerchug.gif) |
930cabman |
Like many I have done it both ways, and far prefer to have the engine on the bench and catch up on other misc items while you are in there.
Access is key |
emerygt350 |
I think the only difficulty is getting your hand in there to clean the area up and that upper bolt on the oil filter mount. I have big hands but I would rank the difficulty as maybe a 2 out of 10. If you had small hands I would say it gets a 1 out of 10. I used a bottle of A and D ointment laying around from when the kids were infants to hold the seals in. Worked great, no slippage. Did the same with the engine out and I could see how well that held the seals in place. Definitely get yourself a ratcheting 10mm wrench for the nuts holding it in place.
And as far as access, I found it way more comfortable laying on my back doing this than crouched over in front of my engine when it was out, but I am getting old and less bendy. |
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,821 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
But if you don't drop the engine, how can you play the "while it's out" game? (IMG:style_emoticons/default/confused24.gif)
Jack Standz |
Member ![]() ![]() Group: Members Posts: 288 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None ![]() |
Come on people, it's only three 10mm (2 easy to get to) nuts and 1 fastener (easy to get to) located at the end of the oil cooler.
For only one fiddly nut, it's such a waste of time and effort to pull the engine IMHO. The reality is that it's so much more difficult just to remove the CV bolts & CVSs. And that's only a small part of removing the motor. Pull out an assortment of small extensions and a universal joint and get that little nut off. Then slide the cooler to the side. Then put some super glue (or grease) on the side of a long skinny screwdriver to properly locate the two seals. Do not over-tighten the fasteners. That's probably why it leaked. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,688 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
... Heck you might even discover you like dropping the engine. http://www.914world.com/specs/tech_engdrop1.php (IMG:style_emoticons/default/smash.gif) |
Superhawk996 |
Come on people . . . I would almost agree with you IF it were only the oil cooler seals leaking. Personally, I’ve never seen an engine with only the oil cooler leaking and everything else in great shape. There are so many other things that can be easily done when the engine is out
This need not turn into Dirk Wright syndrome. But having the engine out is a good time to put eyes on things that would rarely been so easily seen and accessed. |
Porschef |
How you doin' ![]() ![]() ![]() ![]() Group: Members Posts: 2,168 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States ![]() ![]() |
Had to look up Dirk Wright. That one goes back a ways... (IMG:style_emoticons/default/biggrin.gif)
Jack Standz |
This need not turn into Dirk Wright syndrome. But having the engine out is a good time to put eyes on things that would rarely been so easily seen and accessed. I do agree with you. If the front main or rear main seal is leaking, clutch needs replaced, etc., etc. But that wasn't the poster's question. The question was whether to pull the motor to replace leaking oil cooler seals. The answer to that question is no, it's a waste of time and effort. |
Lo-Fi Version | Time is now: 17th June 2024 - 10:06 AM |
