Brakes or struts?, Which way to go |
-JR- |
Nov 16 2023, 11:53 PM
Life goes faster at 150MPH Group: Members Posts: 276 Joined: 12-May 04 From: Victoria BC Canada Member No.: 2,055 |
So I've got a dilemma.
For years I have been collecting parts for my 914-6 project that's underway right now. I acquired a 911 front end clip. Came off an "SC car", but I think now it was a replica because of 3" caliper bolt spacing. Later I acquired some 993 front calipers and then some 986 rears. Now the dilemma... My Boge struts are 3" caliper spacing but at least they are the pin type, not pinch. No one makes 3" to Brembo front adaptors (that I've found and seems to be frowned on) A little background, this is a 3.6L GT car build. These brakes are definitely over kill, but cool, much like the 3.6 and other retro mod improvements. So do I replace the struts or the brakes? I don't want to go away from the Brembo type calipers, but not stuck on the ones I have. Please no ATE brake suggestions. What does the community think? |
Montreal914 |
Nov 17 2023, 12:49 AM
Senior Member Group: Members Posts: 1,590 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Why not go with the Alfa Brembo or get some of PMB's Brembo? All work perfectly on the 3" struts. (IMG:style_emoticons/default/smile.gif)
mepstein |
Nov 17 2023, 06:19 AM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I would suggest consulting with Eric Shea at PMB. But here’s my question. Will 993 and 986 calipers even fit on 3.5 struts and 914 trailing arms? Even with adapters? And will they fit under the wheels you want to use. Do you want the heavy rotors that fit those calipers? E-brake?
So my suggestion is to back up, decide on the brake system you want for the car, sell off the parts you don’t need ( it might be everything) and put together the components that will all work together, fit your car properly and give you the final results you are looking for. (IMG:style_emoticons/default/beerchug.gif) |
BillJ |
Nov 17 2023, 06:22 AM
Senior Member Group: Members Posts: 1,111 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
infraredcalvin |
Nov 17 2023, 06:54 AM
Distracted Member Group: Members Posts: 1,528 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
Another vote (IMG:style_emoticons/default/agree.gif)
Do it right, FWIW I have 993 tt brakes front and rears on my 3.4 -6, it’s nice and cool to have those big reds but really overkill. I have a hard time heating them up on the street, and catch myself over braking on the track…. They barely fit under 16” Fuchs (they require a spacer to clear), and rubber is increasingly hard to find. I’m thinking about downsizing to early turbo brakes, just don’t want to spend the $$$ just yet… Good luck! Post pics of your build please! |
eric9144 |
Nov 17 2023, 11:03 AM
Advanced Member Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
I would suggest consulting with Eric Shea at PMB. But here’s my question. Will 993 and 986 calipers even fit on 3.5 struts and 914 trailing arms? Even with adapters? And will they fit under the wheels you want to use. Do you want the heavy rotors that fit those calipers? E-brake? Yes, yes the do fit (IMG:style_emoticons/default/happy11.gif) I second talking to PMB always for all things brakes. There are adapters readily available to fit the Boxter brakes onto 914 trailing arms, here's the quick google example: https://www.rsrproducts.com/product-page/re...per-adaptor-kit These are 993TT brakes and they fit under 16" Fuchs. You do lose parking brake but might be able to do the 911 parking brake with the tangerine kit. If I were doing it now I'd go Boxter brakes, it's kind of an easy button to modern braking. |
burton73 |
Nov 17 2023, 03:09 PM
burton73 Group: Members Posts: 3,552 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Shown is the front end for Mark. Sonners 2170 RAT Blue car at PMB that was going to be my V8 car, but I changed directions on it. Sent it all to PMB to finish the car. 914-4 a-arms with new rubber bushings, 911 Carrera hubs, 911 Carrera steering rack, turbo tie rods and new bearings and ball joints. Eric set it up with his Alpha calipers on 3 inch.
It is as clean as any I have seen and Eric says it is going to stop big time. Bob B Burton (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/driving-girl.gif) |
worn |
Nov 17 2023, 09:21 PM
can't remember Group: Members Posts: 3,164 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I am thinking that stepping back to the struts that give you 3.5 inch spacing opens up the most doors. Five lug wheels and 911 brakes. I live my 911 s brakes, but doubt that is the best of all possible worlds. The responses show an indication of the many possible routes. Good luck and please keep us posted.
-JR- |
Nov 17 2023, 10:19 PM
Thanks guys!
As per some of the other comments in the thread... Yes the 993 calipers can fit on the car, !BUT! I have the problem I have now. No adaptors for the 3" caliper mounts. Rears aren't a problem, there are adaptors for the there but they are not suppose to be used on the fronts. I like the Alpha caliper idea, but offset becomes an unknown. Not sure what it would take rotor wise or spacing. Anyone on the forum here use these before? So I guess I'm back to the same issue again. I'll also try calling PMB as well! As for the forum "rules" , this post is useless without pictures. So here we go! Here are some recent pictures of my build. I'm about 14mo into it, still in metal. But hope to be spraying epoxy primer in the next couple weeks. I post fairly regularly on Bookface. Attached thumbnail(s) |
mepstein |
Nov 18 2023, 06:04 AM
Alfa calipers have the same spacing and offset as a stock M caliper/914-6. So use an early 911hub (69-72), a 911T rotor (available at flaps, online, PMB, etc) and you are good to go. Fits your 3” struts. Less expensive are 911914-6 am calipers. Send them to PMB to make them new.
A great combo for the rear would be a 911 M caliper and tangerine racing e-brake kit. Low cost but the same piston size as a 914-6 caliper. Uses vented T rotors on the back and all the spacing is correct. The Alfa front, M rear would give you the equivalent of 914-6 brakes with a lighter front caliper/larger pad and use off the shelf parts with out any adapters. Fits every wheel combo. There is a seller or two on eBay offering reproduction Alfa calipers for good prices or find some originals and send to PMB. |
Justinp71 |
Nov 18 2023, 09:11 PM
Senior Member Group: Members Posts: 1,584 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
I did 3.5" struts with wilwood calipers and decent pads. On the track with good pads it braked insanely well, was almost addicting. Now running R4-S porterfield pads on the street and its about perfect. Have the same pads on the rear with 914-6 calipers. |
Lo-Fi Version | Time is now: 10th June 2024 - 10:35 AM |
