| Ottomotion |
Nov 17 2023, 04:53 PM
Member ![]() ![]() Group: Members Posts: 73 Joined: 12-January 23 From: Central California Member No.: 27,090 Region Association: None |
Have a set of 2L fuchs that have been painted with black in the 'low spokes'.
I prefer the factory all metal look. Wondering about recommendations for paint removal. Chemical? Pressure wash? Obviously want to retain the stock look without damaging the underlying alloy. What would you do? Thanks.... |
| mepstein |
Nov 17 2023, 05:53 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,915 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Good chance it was rattle can and may come off pretty easily.
| brant |
Nov 17 2023, 07:30 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,276 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Are they aftermarket Fuchs ?
Could be baked finish very hard Do they have the right part number vs aftermarket? I use easy off oven cleaner The yellow can marked heavy duty Lye in the ingredients Works good on factory anodizing. Less well on powder coat or some baked finishes I’ve stripped about 25 wheels maybe 30 and refinished them now |
| brant |
Nov 17 2023, 07:32 PM
Half of them
Attached thumbnail(s) |
| JeffBowlsby |
Nov 17 2023, 09:57 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,356 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
I recall cleaning up a set with acetone. I think it was prob a rattle can black, nothing very durable.
| Ottomotion |
Nov 17 2023, 11:53 PM
Thanks for the feedback. They are factory and the black seems to be chipped in a few places so i am thinking oven cleaner is a good bet. Just didn't want to ruin them without checking here first.... (IMG:style_emoticons/default/beerchug.gif)
| Unpretentious |
Nov 18 2023, 12:13 AM
Member ![]() ![]() Group: Members Posts: 165 Joined: 23-June 14 From: Calif. Central Valley Member No.: 17,532 Region Association: Central California
I used Klean Strip, available at Home Depot etc., with good and fast results.
| mepstein |
Nov 18 2023, 05:52 AM
Thanks for the feedback. They are factory and the black seems to be chipped in a few places so i am thinking oven cleaner is a good bet. Just didn't want to ruin them without checking here first.... (IMG:style_emoticons/default/beerchug.gif) I would start off with less harsh chemicals first. No reason to strip off the factory anodizing if you don’t need too - unless the factory anodizing has failed and then you might as well go all in. |
| porschetub |
Nov 18 2023, 12:38 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,172 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Thanks for the feedback. They are factory and the black seems to be chipped in a few places so i am thinking oven cleaner is a good bet. Just didn't want to ruin them without checking here first.... (IMG:style_emoticons/default/beerchug.gif) I would start off with less harsh chemicals first. No reason to strip off the factory anodizing if you don’t need too - unless the factory anodizing has failed and then you might as well go all in. (IMG:style_emoticons/default/agree.gif) I would put oven cleaner near them ....please don't plenty of safer ways ,if anodized it will sand off with wet and dry. |
| dhuckabay |
Nov 18 2023, 12:43 PM
Member ![]() ![]() Group: Members Posts: 236 Joined: 14-June 20 From: Idaho Member No.: 24,379 Region Association: Pacific Northwest
Two bits here. Oven cleaner as pointed out above has lye, caustic soda. This eats aluminum very well. Probably not a good choice.
| brant |
Nov 18 2023, 01:02 PM
It’s great for anything that you intend to polish
I’ve got 30 wheels to prove it Yes they get polished after stripping. Sanding if necessary for gouges Then multiple steps of buffing with progressively finer compounds |
| technicalninja |
Nov 18 2023, 01:40 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
The trick for using lye on aluminum stuff is to not leave it on long.
Lye/scrub/wash off in under 90 seconds. Lather, rinse, repeat, as needed. I use oven cleaner for lots of "nasty" removals. If left on too long it will first discolor the alloy and then it will start to eat it. I'd clean any alloy wheel by using increasing powerful cleaners. Dawn dish soap/simple green/normal cleaners first then Acetone, alcohol, B12. Followed by "aluminum safe" paint stripper (this will most likely be citrus based). Real old school paint stripper. Lye based cleaner. The last three I'd be very aware of how long I left it on... Minimum exposure would be my target. Nothing I've ever tried works as good as oven cleaner on cast iron blocks. You can get them to the point it looks like they have been "vatted" in caustic solution. Most machine shops "vats" have serious caustic solutions in them. I once saw a 100+ hour ported Mitsubishi head that a moron paced in one of these vats for 10 minutes. Looked like something out of a horror movie- Total loss... Thank God it wasn't mine. I'd have executed the moron. Lye is a wonderful stripping chemical; I use bunches of it. It can damage alloy things. I always get mine at the dollar store. The cheap stuff is usually lye based. |
| technicalninja |
Nov 18 2023, 01:59 PM
Safety tips:
Oven cleaner: you need variable airflow. The fumes will mess with you. The spray will mess with you MORE! So, during application limited airflow but during "soak" phase strong airflow. You will only allow the overspray to hit you in the eyes ONCE in your lifetime. Any light misting on your hands/arms will rash up quickly. I know these tips from personal experience... Water is the solvent to remove this shit from your body. DON"T GET ANY ON YOU (or in you!). Any nasty cleaning I do over torn down cardboard boxes. I have lots of condenser and radiator boxes which make killer "drop cloths". A carboard box can absorb far more than you would think it can. Don't wash the refuse away. I package my debris up and take it to a proper recycling/hazardous waste center. My 2 cents. |
| Ottomotion |
Nov 18 2023, 08:01 PM
What about using a heat gun?
| technicalninja |
Nov 19 2023, 12:36 AM
Heat will help the cleaners work.
Heat by itself will remove some paints before affecting the aluminum. I'd try to keep the temp at the surface below 250 F I have a German made heat gun (Gartech) that has lasted 30 years and will put out 1100 degrees at max temp. It will fry paint off of anything, but I'd worry about degrading the aluminum at higher temperatures. You will find it's damn hard to heat an aluminum wheel up very much. I might try the Gartech at full kill on the back side of the wheel first. The mass of the wheel is probably so large that even the Gartech would have problems heating it up enough. Heat might work/help. I'd try chemicals first. I used the heat gun to repair a seriously hail damaged minivan once. 1100 degrees until the paint bubbled and blistered (thin sheet metal) then hit it with dry ice. The metal audibly screamed as it shrank back into place. Got 80-90% of the damage removed and was able to fix the remaining issues with standard body work procedures. I really like my heat gun. Used it on a Toyota front wheel bearing install today... |
| Mikey914 |
Nov 20 2023, 12:47 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,784 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Heat is a good way to go. Don't use oven cleaner right away, even if you intend to polish. It will not work on the paint as well as the anodized finish. Remove the paint 1st. You can use aircraft paint remover. It will not attack the aluminum.
You can buy in many hardware stores, even Wallmart. Rustoleum makes a version as well as Klean-strip Then use whatever you plan to strip the anodizing off with. The lye or oven cleaner will not attack the paint as well as the finish making it uneven. Attached thumbnail(s) |
| Unpretentious |
Nov 20 2023, 10:09 PM
I should have been clearer in my earlier response. I used Klean Strip “Aircraft Paint Remover,” as recommended by Gonzo54, with good results.
| MikeK |
Nov 21 2023, 07:46 AM
Member ![]() ![]() Group: Members Posts: 141 Joined: 15-June 23 From: 80906 Member No.: 27,418 Region Association: Rocky Mountains |
Since CA and CO have banned MEK, I've found that most of the strippers hardly work. I recently tried out Kleen Strip on my never ending quest to find something that works as good as the old Aircraft Stripper. I put all the door hardware for my Westfalia in a cup, covered it, left it for three days and the paint barely softened. I ended up blasting it.
The only 'new and improved' product that kind of works is Jasco. It's just way more product and way more time. When it comes time to strip another large project, I'm going to take a road trip to New Mexico to pick up some real stripper. BTW, caustic oven cleaner will turn your aluminum black. Some folks use it to get a magnesium look on their aluminum wheels. |
| Jett |
Nov 21 2023, 12:13 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,700 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest
I bought some citrusstrip and am going to try it on a rattle canned set of 4lug Fuch’s… will take pictures.
Without Al Reed, paint stripper seems like a reasonable thing to try. |
Lo-Fi Version | Time is now: 19th September 2026 - 12:29 AM |
