Flush mount scissor lift, Anyone have opinions? |
r_towle |
Nov 24 2023, 07:56 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I’m building a new place.
I will bring my four post lift and use it for stacking two cars now. I’m considering installing a flush mounted floor lift in the “active” garage bay. Use case is Changing tires, brakes, suspension Once or twice…engine removal from 911 and 914 Any first hand opinions on using this specific flush mounted scissor lift to do engine removals? |
JmuRiz |
Nov 24 2023, 08:49 PM
914 Guru Group: Members Posts: 5,433 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Check out ammo nyc detailer channel. His setup is cool and well used. Feel free to email Larry, he’s always responded to my detailing inquiries
ConeDodger |
Nov 24 2023, 10:41 PM
Apex killer! Group: Members Posts: 23,606 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
They work great. Paul Sayegh flush mounted his before I bought it from him.
Steve |
Nov 24 2023, 11:48 PM
914 Guru Group: Members Posts: 5,606 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
It’s easy to screw together some wooden planks to clear the scissor lift. I didn’t want to damage the concrete floor for a scissor lift.
https://forums.pelicanparts.com/porsche-911...lift-ramps.html |
mepstein |
Nov 25 2023, 06:46 AM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Michael / Cairo had one in his previous house. Lots of info on garage journal on how to do it and build threads of people who have done it. Biggest takeaway is to have the lift in hand to get dimensions for the hole. Don’t rely on manufacturer specifications on dimensions because they might not be true.
mlindner |
Nov 25 2023, 07:48 AM
Senior Member Group: Members Posts: 1,526 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
bahnzai |
Nov 25 2023, 08:17 AM
Member Group: Members Posts: 307 Joined: 26-July 06 From: Columbia, SC Member No.: 6,509 Region Association: South East States |
It is the best money I ever spent in the garage. Made me wonder why I waited so long to do it…
Like Steve, I did not cut the concrete, I did the wood ramps. I wanted the flexibility to move the lift depending on the project, sometimes needing more room at one end than the other, based on the vehicle. |
Cairo94507 |
Nov 25 2023, 08:31 AM
Michael Group: Members Posts: 9,811 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I had a BendPak mid-rise scissor lift which we installed in my garage floor of our Bay Area home (sold) when we did the garage remodel. Best thing we ever did - hands down.
We just broke ground about 3 weeks ago on a new garage, 2,000 sq. (40'x50') with a 14' ceiling. We will pour the floor with 4,300 PSI concrete and go 6" deep. We plan to install a 2-post asymmetrical arm lift, BendPak. Having a lift when you get older is the only way to go. I just am no longer comfortable sitting on the floor or kneeling on the floor to work on cars. This garage is big enough that we may also add a mid-rise scissor lift too. Here are some pictures of my old garage: |
mlindner |
Nov 25 2023, 08:37 AM
Cairo94507, your old garage looks great. Mark
Cairo94507 |
Nov 25 2023, 08:58 AM
Thank you Mark. (IMG:style_emoticons/default/beerchug.gif)
Shivers |
Nov 25 2023, 09:53 AM
Senior Member Group: Members Posts: 2,410 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
@Cairo94507 Oh my goodness dude. I almost wouldn’t want to work in there. (IMG:style_emoticons/default/sawzall-smiley.gif) Almost.
Nice job on the garage. I liked the pop up work bench. Though at my house it would end up a pile of half finished projects waiting for parts, that goes up and down. |
Cairo94507 |
Nov 25 2023, 10:41 AM
@shivers - Those controls are the panel that controls the lift. (IMG:style_emoticons/default/smile.gif)
jc73-914 |
Nov 27 2023, 04:06 PM
Newbie Group: Members Posts: 30 Joined: 28-May 15 From: Richmond, B.C. Canada Member No.: 18,769 Region Association: Canada |
Mine, in the floor. Wooden cover on top to drive over and a 4 x 8 work bench comes out of the floor with a push of a button. very nice, dream garage !! I'm just laboring with my budget Quick Jack (IMG:style_emoticons/default/huh.gif) |
930cabman |
Nov 27 2023, 06:40 PM
Advanced Member Group: Members Posts: 3,130 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
It’s easy to screw together some wooden planks to clear the scissor lift. I didn’t want to damage the concrete floor for a scissor lift. https://forums.pelicanparts.com/porsche-911...lift-ramps.html Exactly how I did mine and it has worked well for several years. Only issue it does not lift quite high enough. It's a HF scissors. I have been considering a two post, but .... If recessed in the floor you lose a couple inches |
arbitrary |
Nov 28 2023, 03:33 PM
Member Group: Members Posts: 81 Joined: 25-April 21 From: UK Member No.: 25,475 Region Association: None |
mepstein |
Nov 28 2023, 06:19 PM
If recessed in the floor you lose a couple inches Which you can pretty much make up for by using thicker rubber blocks… I don’t think so. While we use hockey pucks on the round pads of our two post lift, that’s only a 1” piece of rubber. I wouldn’t put 4 pucks or a 4” block on that pad. It would change the car/lift stability very quickly. |
arbitrary |
Nov 28 2023, 07:30 PM
I have a “platform” mid-rise scissor lift similar to the Bendpak in my garage floor and use thicker rubber blocks without issue.
One of the U.K. “arm” mid-rise scissor lifts comes with a set of different height lift pad extensions. I agree; with that style of lift or a two post I wouldn’t just put a block in place between the pad and the car’s lift point. |
gandalf_025 |
Dec 6 2023, 02:03 PM
Senior Member Group: Members Posts: 1,456 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
mlindner |
Dec 6 2023, 03:03 PM
If recessed in the floor you lose a couple inches Which you can pretty much make up for by using thicker rubber blocks… I don’t think so. While we use hockey pucks on the round pads of our two post lift, that’s only a 1” piece of rubber. I wouldn’t put 4 pucks or a 4” block on that pad. It would change the car/lift stability very quickly. Mark, with mine in floor if I need more lift I use 2x6 six inch square, one to two. Reason, they fit over the round pucks and also to the seam welds....very stable in all four corners. Best, Mark L. |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:38 AM |
