spark plug, how to remove stubborn spark plug from car that sat outside for 14 years. |
jfs911 |
Nov 25 2023, 08:11 PM
Newbie Group: Members Posts: 6 Joined: 10-February 18 From: Toronto,Canada Member No.: 21,878 Region Association: Canada |
bkrantz |
Nov 25 2023, 08:18 PM
914 Guru Group: Members Posts: 7,792 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
How important is the cylinder head? If very important, you might have to remove it to get the plug out without causing damage.
jfs911 |
Nov 25 2023, 08:32 PM
technicalninja |
Nov 25 2023, 09:10 PM
Senior Member Group: Members Posts: 1,290 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
I use "pimp juice" or an essential oil on my stuck corroded fasteners.
Pimp juice is 1/2 Dexron III and acetone. Works great on ferrous to ferrous. Shake well before using as it separates. Ferrous to alloy I use wintergreen oil. This is a health food store item. Any essential oil should work so peppermint oil should suffice. Drench your stuck fastener and leave overnight. |
Superhawk996 |
Nov 25 2023, 09:31 PM
914 Guru Group: Members Posts: 5,876 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
When working with dissimilar metals like aluminum head and steel spark plug body - heat is your best friend.
Do the penetrating oil - pump juice thing 1st. If that fails . . . Then use heat (lots of it). Because the aluminum head is finned and because aluminum conducts heat so well you will need flame - like MAPP gas. A heat gun isn’t going to be enough. Heating the aluminum around the plug causes the hole to expand, breaking corrosion, and reduces the tendency to have the threads binding and galling. Going to be a tough gig with engine tin in place / installed. But if the penetrating lube solutions don’t do it alone, heat will. Way easier to do with the head sitting on the bench. |
IronHillRestorations |
Nov 26 2023, 08:16 AM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Acetone/ATF mix is good, but only mix up what you need as the acetone evaporates fast. The best penetrating spray I’ve found is SeaFoam Deep Creep. I’d soak it for a few days. For future reference milk of magnesia is good anti seize for plugs.
Geezer914 |
Nov 26 2023, 09:26 AM
Geezer914 Group: Members Posts: 1,433 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Being this engine sat outside for years, does the crankshaft turn? A guy gave me a type 4 engine that sat outside and when I removed the heads the pistons were seized in the bores. Not even worth using for a boat anchor.
930cabman |
Nov 26 2023, 02:19 PM
Advanced Member Group: Members Posts: 3,130 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Being this engine sat outside for years, does the crankshaft turn? A guy gave me a type 4 engine that sat outside and when I removed the heads the pistons were seized in the bores. Not even worth using for a boat anchor. I have purchased these before and have found there are not many salvageable parts. |
jfs911 |
Nov 26 2023, 06:33 PM
Being this engine sat outside for years, does the crankshaft turn? A guy gave me a type 4 engine that sat outside and when I removed the heads the pistons were seized in the bores. Not even worth using for a boat anchor. I have purchased these before and have found there are not many salvageable parts. Some great information/options. I will try and see what happens. My friend/mechanic had one of these sitting outside for 10 years, brought it in the shop changed the fuel and some other bits and started the car, and after a few minutes was idling normal. Maybe i will be lucky,but 4 years makes a big difference. thank you all for your input. |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:59 AM |
