qa1142 |
Whiplash ![]() ![]() ![]() Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 ![]() |
Ok so If you do a top end and go stock 2.0L to 2056 with 8.0 - 1 comp.
What is change in Torque? change in HP? What does $350 buy me? |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
about 80cc (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
nebreitling |
Member Emeritus ![]() ![]() ![]() ![]() Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 ![]() |
unless you compete in the car and you're worried about what class it'll land you in, you should definitely spring for the extra displacement. it's a no brainer...
i assume this is with the stock cam and d-jet? you'll want to enrich the mixture for displacement. i'd go for 8.5:1 compression, doubt the cam would want much more, but it's worth a couple hp over 8:1, prolly.... total gain of about 5-10 hp if you do it right. have fun. |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 127,533 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
96's are part of "... the complete package". (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
Its all in the combo!
(and the parts used to attain "The combo") (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) |
Crazyhippy |
Insert witty comment here... ![]() ![]() ![]() Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None ![]() |
A lighter wallet, and lighter is faster (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif)
smg914 |
Sahara Beige Steve ![]() ![]() ![]() Group: Members Posts: 1,977 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None ![]() ![]() |
It'll add balls to your package.
qa1142 |
(IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif)
Seriously what do you get vs. just new rings on the 94MM? 10 ft # of torque 5-10 HP with totally stock set-up? Why not just go with Euro 94's? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
I think the question of Do I wanna stay in Stock class or Street Mod.
96's put you in street mod. Period..... Euro 94's will not bump you in class. HP difference will not make you any faster unless you are running consistently within .10 seconds in all your runs. Now going all out and as Jake pointed out 96's the right cam the proper head work, Exhaust and induction Yea you'll notice a difference. Numbers are hard to nail down. Ball park it will be little more stronger. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) If you don't race then Really why bother. Do you really hold you car wide open for more than 20 seconds? Only if you want a ticket. (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif) |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,990 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
With no other changes figure about a 4% increase in torque/hp. Without doing a top end rebuild you can pick up about 10% by replacing the stock exhaust with one of my Tangerine Evo Header Systems. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
If you are competing in a restricted class my exhaust is the biggest improvement you can make. |
qa1142 |
Thanks Joe
that is probably the answer i was looking for Re-ring, clean-up heads pull 1.8 and drop her in in week or two (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,249 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
why would you tell the person that asked you about mods at the ax that you switched to 96mm pistons? i can't think of anyone that fesses up to ALL the mods done to their cars.
k |
qa1142 |
Its' personnal - I just don't lie. even little white lies SUCK
I won't cheat. Ok, sorry, off my soap box (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
Brando |
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California ![]() |
You don't have to tell anyone what you've done when you're classifying your own car. That's why they developed the 'points' system. So you don't have to disclose what you've done. But if you're an honest person, you'll add the correct number of points (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Lo-Fi Version | Time is now: 15th July 2025 - 03:34 AM |
