Oil filter puzzler - looking for correct filter 914-6 |
roundtwo |
Dec 13 2023, 12:19 PM
Member Group: Members Posts: 282 Joined: 9-February 20 From: Petaluma, CA Member No.: 23,905 Region Association: Central California |
Hello,
Bought a newish to me 914 with 3.0 liter engine with an oil tank installed. Tank custom stainless from Ben M. He wasn't the supplier for the oil filter base plate. Can't figure out what oil filter fits the oil filter plate that's mounted on the tank. An OC28 filter has the right 17mm threads but the filter is too small capacity wise. The base size of that filter looks correct. I need the larger (longer)filter. Tried OC 54 filter but the tread size was incorrect. Any clue what OC filter is correct? Of course I don't know who manufactured the filter plate that mounts on the tank. I called pelican but they don't have thread size specs for the oil filters. Usually they have all the answers to esoteric questions. Ok experts!!! Any ideas here? Thanks, Todd |
mskala |
Dec 13 2023, 01:12 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Recent thread on this:
http://www.914world.com/bbs2/index.php?sho...=366423&hl= |
porschetub |
Dec 13 2023, 02:21 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Hello, Bought a newish to me 914 with 3.0 liter engine with an oil tank installed. Tank custom stainless from Ben M. He wasn't the supplier for the oil filter base plate. Can't figure out what oil filter fits the oil filter plate that's mounted on the tank. An OC28 filter has the right 17mm threads but the filter is too small capacity wise. The base size of that filter looks correct. I need the larger (longer)filter. Tried OC 54 filter but the tread size was incorrect. Any clue what OC filter is correct? Of course I don't know who manufactured the filter plate that mounts on the tank. I called pelican but they don't have thread size specs for the oil filters. Usually they have all the answers to esoteric questions. Ok experts!!! Any ideas here? Thanks, Todd I went for the larger capacity filter think it was an OC 61 but can't read the number on mine cause its on the bottom as mounted but my spare is that number. Pretty sure OC 28 is T4 and yes too small , I bought all spare filters a while back but someone mentioned on here there have been superceded numbers with Mahle. Had a quick look on Pelican and they say the OC 61 as fitting 3.0 SC . Cheers and good luck. |
roundtwo |
Dec 13 2023, 02:41 PM
Thanks for the clues.
It’s the filter for a base like the one picture but with a 17 mm thread not a 22 mm thread. Apparently, this consul bracket is available in different sized threads that accept the filter. It doesn’t have to do with the engine size/ year / model of the car - it has to do with this consul that’s mounted on the oil tank reservoir. Just need the 17 mm vs the 22 mm pictured. Patrick Motorsports sells just this one. Still looking for the bread crumb trail. |
fixer34 |
Dec 13 2023, 10:06 PM
Senior Member Group: Members Posts: 1,090 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
Maybe go back to Ben (mb911) and get one of his console adapters. Should fit if it's his tank. He was selling a kit with the console and OC-54 Made in Austria filter a while back. Get the bigger/correct one and you don't have to chase around looking for filters.
930cabman |
Dec 14 2023, 05:53 AM
Advanced Member Group: Members Posts: 3,148 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
The filter console I have came with an OC54
mb911 |
914 Guru Group: Members Posts: 6,883 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Oc54 for most aftermarket consoles
roundtwo |
Dec 14 2023, 01:25 PM
Thanks for all the help
Anyone know the thread size for an OC 54? I reached out to Ben, and as he mentioned the previous owner could’ve purchased a number of different oil filter mount bases. At least I can order an OC 54 and check it again but I’m almost certain the threads are too small. Need 17mm The OC 28 has the right thread size but the filter canister itself is too short. The base / diameter is the correct size. |
roundtwo |
Dec 14 2023, 02:16 PM
roundtwo |
Dec 14 2023, 02:24 PM
Btw..
OC 54 has a 1 inch connecting thread size After some web fishing….Great website I found for checking filter/ parts specs Autofocus.co.um/spare |
mb911 |
Dec 17 2023, 07:38 AM
Stock 914-6 is stock 911 up to 72. They went to the OC54 the following year. There are some aftermarket filter consoles out there with the smaller earlier thread but I purposely made my consoles accept oc54 filters as they are better and more common.
Lo-Fi Version | Time is now: 10th June 2024 - 04:58 AM |
