WTB Early brake caliper parts |
Archie |
Dec 20 2023, 06:50 PM
Member Group: Members Posts: 197 Joined: 23-September 09 From: Western Canada Member No.: 10,844 Region Association: Pacific Northwest |
davep |
Dec 20 2023, 09:57 PM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
What is the length of the bolts from under the head to the end of the threaded section. I have a few lengths in my parts.
bdstone914 |
Dec 21 2023, 10:52 AM
bdstone914 Group: Members Posts: 4,532 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@Archie
I have brake line nuts that just got yellow zinc plated. If you dont get the bolts from Dave i could pull from a pair of calipers. I think there are two lenghts of the bolts with inner and outer bolts being different lenght. |
bdstone914 |
Dec 21 2023, 12:08 PM
@Archie I have brake line nuts that just got yellow zinc plated. If you dont get the bolts from Dave i could pull from a pair of calipers. I think there are two lenghts of the bolts with inner and outer bolts being different lenght. Yes two lenghts only one is good. Other was cut to remove. Attached thumbnail(s) |
Archie |
Archie |
Dec 21 2023, 12:11 PM
P.S. I'm in Vancouver, so please ignore the US postal address. I'm at V5Z 1B5. Thanks.
davep |
Dec 24 2023, 02:01 PM
Sorry for the delay. I have the bolts you need, and nuts to go with them. I'll dig a bit deeper and see if I have the tube nuts as well. I did have lots, but most were welded up to use as plugs.
Archie |
Dec 25 2023, 03:53 PM
Sorry for the delay. I have the bolts you need, and nuts to go with them. I'll dig a bit deeper and see if I have the tube nuts as well. I did have lots, but most were welded up to use as plugs. It's Christmas, Dave! Everything's out the window at this end! No panic. |
Archie |
Jan 24 2024, 04:50 PM
@Archie I have brake line nuts that just got yellow zinc plated. If you dont get the bolts from Dave i could pull from a pair of calipers. I think there are two lenghts of the bolts with inner and outer bolts being different lenght. Hi again, BDS! So, here I find myself at the back-end of January with two caliper-half bolts and NO tube nuts, so I was wondering if you still have a couple of them you might want to sell me? Thanks |
Archie |
Jan 25 2024, 07:22 PM
@Archie I have brake line nuts that just got yellow zinc plated. If you dont get the bolts from Dave i could pull from a pair of calipers. I think there are two lenghts of the bolts with inner and outer bolts being different lenght. Hi again, BDS! So, here I find myself at the back-end of January with two caliper-half bolts and NO tube nuts, so I was wondering if you still have a couple of them you might want to sell me? Thanks Hi again, BDS. Please disregard my last to you. I've found those tube nuts locally. Thank goodness, I'm way behind on this thing as it is! Sorry to have bothered you! |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:36 AM |
