| 87m491 |
Jan 5 2024, 09:14 AM
Member ![]() ![]() Group: Members Posts: 331 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States
Spending some quality time under the car, really since purchasing it years ago. In replacing all of the cables under the car, accel, clutch, heater flaps and noticed this "mount"? just above the passenger side engine bar mount. Sure looks like it should have a purpose.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-14731-1704467675.1.jpg) |
| IronHillRestorations |
Jan 5 2024, 09:17 AM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,956 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
It’s for the factory style fuel filter which has a square body.
| cpeter |
Jan 5 2024, 09:23 AM
Newbie ![]() Group: Members Posts: 1 Joined: 25-November 16 From: Vienna Member No.: 20,621 Region Association: Austria |
Hello this is the mounting for th Filter. See the attached picture
Greating from Vienna Cornelius ![]() |
| 87m491 |
Jan 5 2024, 10:37 AM
It’s for the factory style fuel filter which has a square body. Thanks. Talk about over built! Unfortunately also found the first "serious" rust so far. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-14731-1704472673.1.jpg) |
| worn |
Jan 5 2024, 07:38 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,650 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
Thanks. Talk about over built! Unfortunately also found the first "serious" rust so far. You need a fuel filter at some point. Fuel tanks aren’t new anymore good luck with the rust |
| ctc911ctc |
Jan 5 2024, 08:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,378 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
Greetings!
Question as to the hoses, the lighter colored hoses seem like the old plastic that was original equipment? can you verify if they are stainless (that is stained) or plastic? Thank you, CTC911CTC Hello this is the mounting for th Filter. See the attached picture Greating from Vienna Cornelius ![]() |
| bkrantz |
Jan 5 2024, 08:23 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,789 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
It’s for the factory style fuel filter which has a square body. Thanks. Talk about over built! Unfortunately also found the first "serious" rust so far. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-14731-1704472673.1.jpg) If that is rusted through, what does the hell hole (top of adjacent box frame member) look like? And what happens if you poke it hard with an awl? |
| 87m491 |
Jan 7 2024, 11:01 AM
Thankfully the rest looks pretty good IMHO.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-14731-1704646914.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-14731-1704646914.2.jpg) It’s for the factory style fuel filter which has a square body. Thanks. Talk about over built! Unfortunately also found the first "serious" rust so far. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-14731-1704472673.1.jpg) If that is rusted through, what does the hell hole (top of adjacent box frame member) look like? And what happens if you poke it hard with an awl? |
| 87m491 |
| 87m491 |
Jan 7 2024, 11:02 AM
| rgalla9146 |
Jan 7 2024, 12:08 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,997 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Greetings! Question as to the hoses, the lighter colored hoses seem like the old plastic that was original equipment? can you verify if they are stainless (that is stained) or plastic? Thank you, CTC911CTC Hello this is the mounting for th Filter. See the attached picture Greating from Vienna Cornelius ![]() Yes, that is original plastic fuel tubing. And the original plastic Y junction. Very unusual to see those original parts still in use. The hose routing is difficult to follow and could be made neater but it was a crowded arrangement from new. On a 914 6 one plastic tube extended up to the carb supply On a 4cyl. plastic supply and return tubes extended up through the engine shelf. |
Lo-Fi Version | Time is now: 21st September 2026 - 09:49 AM |
