Clutch Arm Freeplay and Starter Questions |
gnomefabtech |
Jan 18 2024, 01:11 PM
Member Group: Members Posts: 111 Joined: 27-December 22 From: Los Angeles Member No.: 27,063 Region Association: None |
Hello Gang-
I'm finally getting everything on my project assembled and I noticed that the clutch are has very little freeplay. Around an 1/8". Regular 901 trans with a Kennedy pressure plate. I have heard that there can be shims under the pivot ball but I'm not sure what the freeplay should be so I'm not sure if I should remove any shims. Next question is if there are any lightweight starters for our cars. The OG starter is pretty giant by modern standards. Will a starter off a Bug work because there seem to be a lot of options then. Thanks |
rick 918-S |
Jan 18 2024, 01:19 PM
Hey nice rack! -Celette Group: Members Posts: 20,471 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
No Free Play on th clutch arm.
gnomefabtech |
Jan 18 2024, 04:21 PM
Thanks for the reply. Just seems odd that the throwout bearing would be in constant contact with the clutch diaphragm but I guess a tiny bit of play is enough. Any thoughts on a compact starter?
peteinjp |
Jan 18 2024, 05:20 PM
Member Group: Members Posts: 201 Joined: 15-July 21 From: Japan Member No.: 25,723 Region Association: None |
I went through all of this earlier this year. I have all parts to replace the clutch also using kennedy stuff. Check out this thread, and see if it get, you started with your questions:
http://www.914world.com/bbs2/index.php?sho...;hl=Kennedy+arm |
gnomefabtech |
Jan 19 2024, 11:16 AM
That makes sense now. Looks like I'm in good shape with the maximum clutch release action.
Does anyone know if a Bug starter fits our cars? Because there are some nice lightweight options there. |
peteinjp |
Jan 19 2024, 09:05 PM
Look for a WOSP for a 914.
Pete |
brant |
Jan 20 2024, 07:38 AM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Get a tilton starter
Gear reduction and lighter Don’t think a bug starter would work |
peteinjp |
Jan 20 2024, 08:25 PM
Steve |
Jan 21 2024, 08:49 AM
914 Guru Group: Members Posts: 5,606 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
(IMG:style_emoticons/default/hijacked.gif)
I just went through this mess with my SBC 914. I have a KEP stage 3. Everything seemed fine until I installed a new trans that had a washer behind the pivot ball. Now the clutch cable was too short, so I extended the cable versus pulling the trans. Everything seemed wonky, so I pulled the trans removed the washer and installed a new Gemo cable. To get the clutch to disengage correctly, I now have no free play at the pedal. The throw out bearing is probably riding on the pressure plate, but at least it’s working. |
gnomefabtech |
Jan 21 2024, 05:46 PM
Engine is still out of the car. I'll pull the trans off and see if there is a spacer under there. The arm is so far forward that it touches the housing of the pressure plate if you don't pull it back.
worn |
Jan 21 2024, 06:46 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Lo-Fi Version | Time is now: 1st June 2024 - 03:51 AM |
