gnomefabtech
Jan 18 2024, 01:11 PM
Hello Gang-
I'm finally getting everything on my project assembled and I noticed that the clutch are has very little freeplay. Around an 1/8". Regular 901 trans with a Kennedy pressure plate. I have heard that there can be shims under the pivot ball but I'm not sure what the freeplay should be so I'm not sure if I should remove any shims.
Next question is if there are any lightweight starters for our cars. The OG starter is pretty giant by modern standards. Will a starter off a Bug work because there seem to be a lot of options then.
Thanks
rick 918-S
Jan 18 2024, 01:19 PM
No Free Play on th clutch arm.
gnomefabtech
Jan 18 2024, 04:21 PM
Thanks for the reply. Just seems odd that the throwout bearing would be in constant contact with the clutch diaphragm but I guess a tiny bit of play is enough. Any thoughts on a compact starter?
peteinjp
Jan 18 2024, 05:20 PM
I went through all of this earlier this year. I have all parts to replace the clutch also using kennedy stuff. Check out this thread, and see if it get, you started with your questions:
http://www.914world.com/bbs2/index.php?sho...;hl=Kennedy+arm
gnomefabtech
Jan 19 2024, 11:16 AM
That makes sense now. Looks like I'm in good shape with the maximum clutch release action.
Does anyone know if a Bug starter fits our cars? Because there are some nice lightweight options there.
peteinjp
Jan 19 2024, 09:05 PM
Look for a WOSP for a 914.
Pete
brant
Jan 20 2024, 07:38 AM
Get a tilton starter
Gear reduction and lighter
Don’t think a bug starter would work
peteinjp
Jan 20 2024, 08:25 PM
QUOTE(brant @ Jan 20 2024, 10:38 PM)
I had bad results with the Hi-torque brand.
Steve
Jan 21 2024, 08:49 AM
I just went through this mess with my SBC 914. I have a KEP stage 3. Everything seemed fine until I installed a new trans that had a washer behind the pivot ball. Now the clutch cable was too short, so I extended the cable versus pulling the trans. Everything seemed wonky, so I pulled the trans removed the washer and installed a new Gemo cable. To get the clutch to disengage correctly, I now have no free play at the pedal. The throw out bearing is probably riding on the pressure plate, but at least it’s working.
gnomefabtech
Jan 21 2024, 05:46 PM
Engine is still out of the car. I'll pull the trans off and see if there is a spacer under there. The arm is so far forward that it touches the housing of the pressure plate if you don't pull it back.
worn
Jan 21 2024, 06:46 PM
QUOTE(rick 918-S @ Jan 18 2024, 12:19 PM)
Right. Not knowing this caused me a great deal of money and time. Seems strange but it isn’t the only ball bearing in the car constantly spinning. Go figure though.
