Window Rubber Help Please |
76-914 |
Jan 27 2024, 04:02 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
instead of adding a post each time try going back and editing one of these posts or add to this one.
SirAndy |
Jan 27 2024, 04:14 PM
Resident German Group: Admin Posts: 41,671 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
@kenshapiro2002
And ditch that Apple device you're using and use a real computer instead ... (IMG:style_emoticons/default/rolleyes.gif) |
krazykonrad |
Jan 27 2024, 04:25 PM
Senior Member Group: Members Posts: 1,128 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 |
Our very own Ian Karr just put this up:
https://www.youtube.com/watch?v=FCbuWuLjB3U Window rubber included. |
kenshapiro2002 |
Jan 27 2024, 04:37 PM
Senior Member Group: Members Posts: 1,441 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
I need to replace the horizontal rubber piece under the window. Not the fuzzy that is on the inside, but the rubber piece that just fits into the metal channel and rests on the actual door.. Wondering if I can just slide or press that into the channel once I remove the old one or do I need to actually takeoff the door panel and do more than that
krazykonrad |
Jan 27 2024, 05:01 PM
@iankarr
Mikey914 |
Jan 27 2024, 05:26 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
@16:15 ish Note we now make the seal with a fuzzy strip on it so the glass will not grab it. The OEM didn't have it so when we 1st made it we made just like OEM. Since the later seal is really a 911 seal that was used in place of the early seal, the late one grabbed.
Also, if you roll the window up a little you can use a wood block to press the seal into the channel. If you channel is dorked up where folks have used screw drivers to open it up we have new ones. Both early and late (as well as the early rubber seal). https://914rubber.com/late-outer-window-scr...eal-w-fuzzy-set Attached image(s) |
Lo-Fi Version | Time is now: 4th June 2024 - 09:43 AM |
