Like this New Style Elec Connector |
76-914 |
Feb 7 2024, 09:04 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
NARP74 |
Feb 7 2024, 09:10 AM
Senior Member Group: Members Posts: 1,072 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Interesting
Superhawk996 |
Feb 7 2024, 09:23 AM
914 Guru Group: Members Posts: 5,878 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Alert: I’m always a cynic.
Great way to make poorly crimped butt connections even harder to troubleshoot and fix. (IMG:style_emoticons/default/happy11.gif) Remind me again, what problem does this solve? On the other hand - it is an opportunity to buy a new tool. (IMG:style_emoticons/default/laugh.gif) |
Maltese Falcon |
Advanced Member Group: Members Posts: 4,686 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
I like the concept but could get crowded, if putting several connections in a tight space or corner. I'd def wear a thermal glove on that one hand...if you have ever experienced a hot glue gun !
(IMG:style_emoticons/default/marty914.jpg) |
ClayPerrine |
Feb 7 2024, 09:26 AM
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Jeff_72 |
Feb 7 2024, 10:10 AM
Newbie Group: Members Posts: 24 Joined: 15-October 22 From: Texas Member No.: 26,921 Region Association: Southwest Region |
Damnit. I was just starting to get good at butt connections. Now I need a new tool.
windforfun |
Feb 7 2024, 10:19 AM
Senior Member Group: Members Posts: 1,823 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
That's total BS IMHO. Here's how you do it, followed by soldering & shrink tubing.
https://en.wikipedia.org/wiki/Western_Union_splice (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) |
GregAmy |
Feb 7 2024, 10:35 AM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
That's total BS IMHO. Here's how you do it, followed by soldering & shrink tubing. Yup. That's a cool replacement for a basic butt splice (could be handy to have a screw hanger) but I much prefer the Western Union twist/solder/heat shrink for important stuff that I never want to have to look at ever again. Or, better yet, re-run the whole wire so there's not a junction. I cannot express enough distaste for crimped butt connectors. I will use them at times, while holding my nose. But if I want it done right... |
technicalninja |
Feb 7 2024, 11:31 AM
Senior Member Group: Members Posts: 1,300 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
That's total BS IMHO. Here's how you do it, followed by soldering & shrink tubing. https://en.wikipedia.org/wiki/Western_Union_splice (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) I've used that for decades. I was calling it the wrong name. I called it A&P or NASA style. (IMG:style_emoticons/default/av-943.gif) They just appropriated it from someone else! I've tested three splice spans (20,16,14) for both resistance and failure. No difference in resistance on a Fluke 87 and they never failed at the splice when the wire was shock tested to breakage. In 30+ years I've never had to re-do a splice done this way. For the last 8 years I have been using type 2 heat shrink with the glue lining. Once you get "good" your spice will look like you just added heat shrink to a wire. Almost no diameter change. |
ClayPerrine |
Feb 7 2024, 11:37 AM
That's total BS IMHO. Here's how you do it, followed by soldering & shrink tubing. https://en.wikipedia.org/wiki/Western_Union_splice (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) I've used that for decades. I was calling it the wrong name. I called it A&P or NASA style. (IMG:style_emoticons/default/av-943.gif) They just appropriated it from someone else! I've tested three splice spans (20,16,14) for both resistance and failure. No difference in resistance on a Fluke 87 and they never failed at the splice when the wire was shock tested to breakage. In 30+ years I've never had to re-do a splice done this way. For the last 8 years I have been using type 2 heat shrink with the glue lining. Once you get "good" your spice will look like you just added heat shrink to a wire. Almost no diameter change. I have been doing western union splices for years. If possible, I prefer not to have a splice. But it is not always possible. This appears to be a waterproof splice that would hold up well. And that can be used without the metal crimp connector, just use a western union splice, solder , then put it in their contraption and you have a waterproof junction. I can't see heat shrink being waterproof. |
JmuRiz |
Feb 7 2024, 11:56 AM
914 Guru Group: Members Posts: 5,433 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
I saw the new connectors with solder and heat-shrink in one. Just need to wind wires and hit it with a heat gun to melt the solder and heat-shrink in one step.
That seems like a better solution |
tygaboy |
Feb 7 2024, 01:14 PM
914 Guru Group: Members Posts: 5,303 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
I didn't take that they were claiming it's a "connector". Rather that it makes waterproof whatever sort of splice has been made.
I will say that hanger idea may have some handy applications. But wiring-wise, I'm good with what I've been doing: crimp, DR-25 heat shrink, SCL for sealing, cable ties to secure things. Now get off my lawn! |
windforfun |
Feb 7 2024, 04:40 PM
I've had to make similar repairs in the car due to bad factory workmanship & rodents. I remove a full 1" of insulation. I use a thermal insulation stripper. No cut or nicked strands. CW twisting for both bare wire strands & junction. All of the Porsche wiring thus far has used CW strand twisting. Rosin core solder & shrink tubing. I also use wire from an old harness, if necessary, & run whatever printing is on the wire in the same direction as what's in the car. This repair took several hours. This is hard work IMHO. CTTOI, in my 40 years of electronics work, I've only once encountered CCW strand twisting. Whatever.
(IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) Attached thumbnail(s) |
76-914 |
Feb 7 2024, 05:48 PM
That's total BS IMHO. Here's how you do it, followed by soldering & shrink tubing. https://en.wikipedia.org/wiki/Western_Union_splice (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) I've used that for decades. I was calling it the wrong name. I called it A&P or NASA style. (IMG:style_emoticons/default/av-943.gif) They just appropriated it from someone else! I've tested three splice spans (20,16,14) for both resistance and failure. No difference in resistance on a Fluke 87 and they never failed at the splice when the wire was shock tested to breakage. In 30+ years I've never had to re-do a splice done this way. For the last 8 years I have been using type 2 heat shrink with the glue lining. Once you get "good" your spice will look like you just added heat shrink to a wire. Almost no diameter change. I have been doing western union splices for years. If possible, I prefer not to have a splice. But it is not always possible. This appears to be a waterproof splice that would hold up well. And that can be used without the metal crimp connector, just use a western union splice, solder , then put it in their contraption and you have a waterproof junction. I can't see heat shrink being waterproof. Bingo Clay. Add to that it looks a damn site better than heat shrink tube. Yes, I use the Marine type but this doubles up your bet against corrosion or a leak. More especially for the one who is not well versed in electrical connections. This type seal will also will end the conversation about solder joints breaking from vibration/flexing. It would surprise me if someone looked in the engine bay and complained about one of these. I remember when they came out with PVC pipe. I was a kid and the old timers were screaming "I wouldn't use that shit if they paid me!" (IMG:style_emoticons/default/av-943.gif) |
Superhawk996 |
Feb 7 2024, 08:15 PM
I didn't take that they were claiming it's a "connector". Rather that it makes waterproof whatever sort of splice has been made. I will say that hanger idea may have some handy applications. But wiring-wise, I'm good with what I've been doing: crimp, DR-25 heat shrink, SCL for sealing, cable ties to secure things. Now get off my lawn! I want You doing all my connections! Your wiring harness workman ship is the best ever ever seen from an “amateur”. Right tools, right techniques. (IMG:style_emoticons/default/pray.gif) @tygaboy . |
GregAmy |
Feb 7 2024, 09:07 PM
Whe I did the Microsquirt project, I wrote:
I wanted to avoid -- if not outright eliminate -- butt connecting or splicing wires; everything should terminate inside a pin housing. I also wrote: oof. Had I known in advance how much brainpower and effort this was going to take...let's just say it was a lot of work. I hate farked up wiring. Really, I do. That was a TON of work. But I'm hoping I won't have to do it again. |
davep |
Feb 10 2024, 09:44 AM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
windforfun |
Feb 10 2024, 10:40 AM
I use a thermal insulation stripper. Please provide more information; brand & model? Here you go. There aren't any labels on it. It's made by Ungar. I found it on eBay. Attached thumbnail(s) |
Spoke |
Feb 10 2024, 11:04 AM
Jerry Group: Members Posts: 6,989 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I thought is was rule of thumb not to use solder joints in a vehicle because of the flexing and that only crimped joints should be used.
About the waterproof hot melt method that looks like it would be good for outdoor applications. I have lighting around my pond and the connections are exposed to the weather and oxidize and tarnish easily. |
windforfun |
Feb 10 2024, 11:08 AM
I thought is was rule of thumb not to use solder joints in a vehicle because of the flexing and that only crimped joints should be used. About the waterproof hot melt method that looks like it would be good for outdoor applications. I have lighting around my pond and the connections are exposed to the weather and oxidize and tarnish easily. Between the Western Union style splice, soldering, & shrink tubing, I don't think vibration is an issue. I've never had any problems whatsoever over several decades. If using a spade lug connector, lets say, you don't want to tin & then crimp because the tin solder will flow or deform with time & the connection will loosen. You want to crimp first & then flow solder into the crimp joint & then use heat shrink tubing. This is how Mercedes does it. |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:04 PM |
