vintage914racer |
Member ![]() ![]() Group: Members Posts: 429 Joined: 28-December 03 From: Minneapolis, MN Member No.: 1,473 ![]() |
The speedometer drive gear bushing is leaking transmission fluid on my car, which doesn't have a speed angle drive.
The existing bushing appears to have a bunch of epoxy over where the drive gear would go and that's not where it's leaking. Rather it's leaking between the bushing and case. I I'm confident one of the updated double o-ring bushings would do the trick, as it did on my 914-6 street car,, but I'm curious what the best approach would be to plug and make the void where the angle drive would normally go on the track car? There must be a more elegant way than just gooping it up with epoxy like I currently have? |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Don’t have a picture handy of the inside
But we took the center /drive out Then TIG welded the aluminum housing to close the hole Reinstalled an tightened Put a plastic cap over it Attached image(s) ![]() |
vintage914racer |
Don’t have a picture handy of the inside But we took the center /drive out Then TIG welded the aluminum housing to close the hole Reinstalled an tightened Put a plastic cap over it Makes sense. That was the solution I was thinking of, so glad to hear someone else has done it. |
Lo-Fi Version | Time is now: 10th June 2024 - 06:00 PM |
