Removing those Tiny Lamps in the Flasher Knob |
76-914 |
Feb 13 2024, 07:01 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
If you have fat fingers like I do it is a PITA changing out those tiny bulbs. I usually end up breaking them with needle nose pliers. I needed to replace the one in my rear window defogger switch and tried this instead . Works like a charm and everybody has one.
FlacaProductions |
Feb 13 2024, 07:24 PM
Senior Member Group: Members Posts: 1,618 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Necessity is the mother....
914_teener |
Feb 13 2024, 07:27 PM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I also use that same setup for cleaning out excess hair and ear wax from my ears!
Only a plumber would think of this...thanks Kent! |
windforfun |
Feb 13 2024, 07:48 PM
Senior Member Group: Members Posts: 1,841 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
That's disgusting. Try a pressure washer next time. Just don't blow out what's left of your ear drums.
(IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) |
windforfun |
Feb 13 2024, 07:50 PM
If you have fat fingers like I do it is a PITA changing out those tiny bulbs. I usually end up breaking them with needle nose pliers. I needed to replace the one in my rear window defogger switch and tried this instead . Works like a charm and everybody has one. Very high (low) tech, but I like it. I'll remember this. (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) |
Root_Werks |
Feb 13 2024, 08:56 PM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
That's really cool! I remember breaking a bulb by using needle nose pliers.
913B |
Feb 15 2024, 08:18 PM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
nice tip,
Thanks |
StarBear |
Feb 16 2024, 08:17 AM
Senior Member Group: Members Posts: 1,913 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Does the headlight knob have those lights? They work on my flasher and fog light knobs but don’t recall seeing the headlight (or cigarette lighter) knobs light up.
76-914 |
Feb 16 2024, 09:32 AM
914_teener |
Feb 16 2024, 11:14 AM
One more place IRIC;
On the tunnel right by the heat lever....comes on when the lights are on. |
76-914 |
Feb 25 2024, 08:09 PM
One more place IRIC; On the tunnel right by the heat lever....comes on when the lights are on. And the fresh air/defrost slide controller has some lamps too. That pencil eraser comes in handy while trying to touch the ohm meter test probes on those two tiny little wire leads. |
Lo-Fi Version | Time is now: 10th June 2024 - 05:43 PM |
