| robertggross |
Feb 19 2024, 03:22 PM
Newbie ![]() Group: Members Posts: 1 Joined: 1-December 21 From: Beaufort, SC Member No.: 26,126 Region Association: South East States |
Does anyone have a hydraulic clutch kit for a '72 914 with a side shift?
Thanks! |
| Front yard mechanic |
Feb 19 2024, 08:11 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,438 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None
Toyota
| Steve |
Feb 20 2024, 09:40 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,026 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
Does anyone have a hydraulic clutch kit for a '72 914 with a side shift? Thanks! I have never seen a complete kit. Do a search, their was a member that sold the piece to modify the pedals for the master cylinder. The trans end was always fabricated in different ways. |
| 76-914 |
Feb 20 2024, 09:45 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,872 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
You'll need to use a 3/4" pull type slave cylinder & 5/8" MC. IIRC, Mark did this on his 914 @Euro911 .
| Steve |
Feb 22 2024, 10:38 AM
Here's a link to a good thread that shows the pedal bracket and other parts.
http://www.914world.com/bbs2/index.php?sho...311&st=100# |
| ClayPerrine |
Feb 22 2024, 10:41 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Contact Rich Johnson (a914guy@aol.com). I don't know if he still does. but he sold a kit for years.
| euro911 |
Feb 22 2024, 08:25 PM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
| ClayPerrine |
Feb 23 2024, 07:36 AM
This page in my build thread shows how I put in the Hydraulic clutch master cylinder.
http://www.914world.com/bbs2/index.php?sho...9084&st=120 And here is the later revision to the clutch master cylinder linkage. http://www.914world.com/bbs2/index.php?sho...9084&st=240 I can't help with the transmission end. The Cayman 6-speed has a hydraulic slave cylinder built into it. |
| Steve |
Feb 23 2024, 10:03 AM
I am curious does it help reduce pedal pressure? I have a stage 3 KEP clutch with my SBC/914 trans and at my age its killing my foot in stop and start traffic.
| ClayPerrine |
Feb 23 2024, 03:57 PM
I am curious does it help reduce pedal pressure? I have a stage 3 KEP clutch with my SBC/914 trans and at my age its killing my foot in stop and start traffic. I have the same issue with the clutch in the 4.0L car. The clutch is VERY heavy. That can be mitigated by making the master cylinder bigger. I am going to try that when the motor goes back into my car. |
| aturboman |
Feb 23 2024, 08:05 PM
Member ![]() ![]() Group: Members Posts: 151 Joined: 18-October 11 From: CA Member No.: 13,687 Region Association: None |
This is a hydraulic pedal assembly using all Genuine Porsche bits. G50 + 911 parts.
Just fits under the stock pedal board. ![]() |
| Superhawk996 |
Feb 23 2024, 08:55 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,753 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
I am curious does it help reduce pedal pressure? I have a stage 3 KEP clutch with my SBC/914 trans and at my age its killing my foot in stop and start traffic. I have the same issue with the clutch in the 4.0L car. The clutch is VERY heavy. That can be mitigated by making the master cylinder bigger. I am going to try that when the motor goes back into my car. Just to clarify the hydraulics To reduce clutch pedal force, the clutch master cylinder goes to a smaller diameter (but longer stroke) and/or the slave cylinder gets larger. |
| ClayPerrine |
Feb 24 2024, 06:07 AM
| aturboman |
Feb 25 2024, 09:44 AM
Agreed, requires a slight clearance bump in the sheetmetal but its all factory. The rest is plug and play.
This is a hydraulic pedal assembly using all Genuine Porsche bits. G50 + 911 parts. Just fits under the stock pedal board. ![]() I tried that. It didn't fit. The clutch master cylinder ran into the body sheet metal. |
| dwillouby |
Feb 26 2024, 02:30 PM
Member ![]() ![]() Group: Members Posts: 395 Joined: 27-December 02 From: Mt Washington, KY Member No.: 29 Region Association: None
Does anyone have a hydraulic clutch kit for a '72 914 with a side shift? Thanks! Hi Used to offer a kit. These are the parts I used. Dont have any remaining mounting brackets although. The following list is the part numbers, description, and vendor price for the parts I sourced. • Wilwood remote master cyl. ¾ bore, WIL-260-6089, Summit Racing $47.94 • -3 AN PTFE Hose, SUM-220981 @ 20 ft (may only need estimated 12ft) Summit Racing $40.49 • 7/16-20 to 5/16 hose barb fitting, 3207, Pegasus racing www.pegasusautoracing.com $24.99 • (2) 90 deg. -3 fitting, AER-FBM1120, Summit Racing $12.97 ea. • -3 AN hose to female -3AN straight steel fitting, AER-FBM1120, Summit Racing $8.97 • 3/8-24 to -3AN Male adaptor WIL-220-3406, Summit Racing $2.99 • 5/16 rubber tubing from master cyl. to reservoir, Auto Zone $ ?? • Remote Reservoir WIL-260-7577, Summit Racing $59.94 (Mine leaked I sourced a replacement from an older Chevy S-10). David |
| dwillouby |
Feb 26 2024, 02:33 PM
Forgot the slave
• Howe Racing slave cyl; HRE-829, Summit Racing $53.97* |
| mb911 |
Jul 15 2025, 03:03 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,723 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
Does anyone have a hydraulic clutch kit for a '72 914 with a side shift? Thanks! Hi Used to offer a kit. These are the parts I used. Dont have any remaining mounting brackets although. The following list is the part numbers, description, and vendor price for the parts I sourced. • Wilwood remote master cyl. ¾ bore, WIL-260-6089, Summit Racing $47.94 • -3 AN PTFE Hose, SUM-220981 @ 20 ft (may only need estimated 12ft) Summit Racing $40.49 • 7/16-20 to 5/16 hose barb fitting, 3207, Pegasus racing www.pegasusautoracing.com $24.99 • (2) 90 deg. -3 fitting, AER-FBM1120, Summit Racing $12.97 ea. • -3 AN hose to female -3AN straight steel fitting, AER-FBM1120, Summit Racing $8.97 • 3/8-24 to -3AN Male adaptor WIL-220-3406, Summit Racing $2.99 • 5/16 rubber tubing from master cyl. to reservoir, Auto Zone $ ?? • Remote Reservoir WIL-260-7577, Summit Racing $59.94 (Mine leaked I sourced a replacement from an older Chevy S-10). David This is incredibly helpful thank you. |
Lo-Fi Version | Time is now: 23rd March 2026 - 07:39 PM |
