> stubborn exhaust manifold gaskets
87m491
post Feb 20 2024, 06:55 AM
Finally swapping in SS heater boxes I acquired years ago and I can't budge the existing manifold gaskets. I have read and tried a few options, trying to leverage a pick under and edge and walk it out, no luck., the gasket is very tight against the engine. Trying to lever a screwdriver head against and gasket edge and the head to deform the gasket a touch except that my head's fin started to deform before the gasket! Any other tricks before I give up and just try reusing the gaskets that won't seem to come out?
Thx
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-14731-1708433712.1.jpg)
Replies(1 - 19)
barefoot
post Feb 20 2024, 06:56 AM
If they're not damaged in the sealing face, just re-use them.
windforfun
post Feb 20 2024, 11:52 AM
What is the gasket material? Can you cut them?
(IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/idea.gif)
TROJANMAN
post Feb 20 2024, 12:17 PM
Looks nice in pictures.........
When all else fails, torch it. (IMG:style_emoticons/default/devil.gif)
Shivers
post Feb 20 2024, 12:22 PM
I agree, throw some flame on it.
930cabman
post Feb 20 2024, 01:24 PM
It's hard for me to see, but if it's the copper sealing ring, I go after these with a narrow screwdriver and deform it (collapse it) and then pull it out.
87m491
post Feb 20 2024, 04:46 PM
Theoretically copper but not very malleable from my efforts.
QUOTE(windforfun @ Feb 20 2024, 09:52 AM) *
87m491
post Feb 20 2024, 04:48 PM
QUOTE(930cabman @ Feb 20 2024, 11:24 AM) *
As noted, BTDT and the engine metal deformed before the gasket. Will try the heat suggestion. If not luck I'll leave them in.
GregAmy
post Feb 20 2024, 05:35 PM
I snag 'em with a bent pick. $10 for "the good ones" at HF.
https://www.harborfreight.com/pick-and-hook...iece-69592.html
They're cheap enough I'll almost always replace the seals. I keep a handfull in my toolbox because I don't want to have to do the job again.
DC_neun_vierzehn
post Feb 20 2024, 05:51 PM
Sounds like someone may have applied some sealant when they installed those and they baked the copper rings on real good. Or those suckers have just been on there forever. Applying some heat to the rings could help. I would try to work a pick around the entire edge of the copper rings (delicately and then more forcefully with each full rotation) before applying heat.
windforfun
post Feb 20 2024, 06:05 PM
QUOTE(GregAmy @ Feb 20 2024, 03:35 PM) *
This kinda reminds me of what my dentist uses. And he's board certified.
(IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif)
930cabman
post Feb 20 2024, 07:08 PM
QUOTE(windforfun @ Feb 20 2024, 07:05 PM) *
Which board is he certified? 2x4?
Eric_Ciampa
post Feb 20 2024, 07:57 PM
CHAMP914
I remember deforming one stubborn one. I might have used a punch to deform and create a flat lip to pull out.
87m491
post Feb 25 2024, 02:16 PM
QUOTE(DC_neun_vierzehn @ Feb 20 2024, 03:51 PM) *
Indeed. I took a smallish flat head screwdriver and reformed the last 1/4 inch at a 90 degree angle and could not get under the gasket. I used a cold chisel to cut/deform the gasket, which they did, see copper colored areas in the picture, but still absolutely no opening to lever/pull against. Then tried propane always fun 12 inches from your face. Absolutely won't budge. I reinstalled the heat exchangers and will revisit next fall when I drop the engine to reseal it and can attack from a better angle.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-14731-1708892176.1.jpg)
rhodyguy
post Feb 25 2024, 02:36 PM
A couple of whacks on the ring with a hammer and sharp narrow wood chisel helps getting stuck ones out. The copper is fairly soft.
windforfun
post Feb 25 2024, 04:26 PM
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif)
Cut them with a sharp steel wood chisel. You'll probably need to sharpen the chisel afterwards. Use a bench grinder & an oil stone.
technicalninja
post Feb 25 2024, 05:11 PM
QUOTE(87m491 @ Feb 25 2024, 02:16 PM) *
That one is toast now!
If you run that the groove will allow a 1000+ degree leak that will eat the head casting...
That needs to be replace now IMO.
930cabman
post Feb 27 2024, 02:57 PM
Attached Image Long thin blade slotted screwdriver, a good rap with a SMH
Attached Image Deformed copper gasket
Attached Image Done like dinner
rjames
post Feb 27 2024, 08:15 PM
I'm made of metal
Don't run it without replacing it first.
worn
post Feb 27 2024, 08:26 PM
QUOTE(930cabman @ Feb 20 2024, 05:08 PM) *
Keep this in mind: to anneal and soften copper you heat till they glow a dull red and quench it in cold water. That hardens steel, but it softens copper silver or gold. You want the gasket soft enough to deform.
- Lo-Fi Version Time is now: 5th August 2026 - 02:22 AM
